פורסם 2009 באפריל 317 שנים שלום לכולם, מה דעתכם על המחשב הנייד הבא? לשימוש ביתי בלבד לאופיס וסרטים. גודל המסך שאני מחפש הוא: 15.4 inch - 17 inch- תודה מראש!!! Acer Aspire 6930G-944G64Mn Gemstone Blue 16-inch Notebook Operating System: Genuine Windows Vista Ultimate Processor: Intel Core 2 Duo T9400 (2.53GHz, 6MB L2 cache, 1066FSB, 64-bit) Screen: 16-inch WXGA Wide Screen CrystalBrite (1366 x 768, 8 msec response) Memory: 2GB DDR2-SDRAM 667MHz SODIMM Memory 2: 2GB DDR2-SDRAM 667MHz SODIMM Hard Drive: 640GB SATA 5400rpm hard drive Optical Drive: DVD-Super Multi drive Software: No additional software Warranty: 2 year Courier Pickup and Return Service Intel Centrino Processor technology Mobile Intel PM45 Express Chipset Long life Lithium Ion battery up to 2.5 hrs life NVIDIA GeForce 9600M GS with up to 23037 MB of TurboCache (512 MB of dedicated DDR2 VRAM, up to 1791 MB of shared system memory) DVBT Digital High Definition TV Tuner + Media Center Remote Control Optimised 2nd generation Dolby Home Theater audio enhancement featuring Dolby Digital, Dolby Digital Live, Dolby Pro Logic IIx, Dolby Headphone and Dolby Natural Bass and Dolby Sound Space Expander technologies, Acer CineSurround with five built-in speakers and one Acer Tuba CineBass booster supporting low-frequency effects True5.1-channel surround sound output, High-definition audio support, S/PDIF support for digital speakers, MS-Sound compatible, Acer PureZone technology with two built-in stereo microphones featuring beam forming, echo cancellation, and noise suppression technologies Integrated Acer Crystal Eye webcam, supporting Acer PrimaLite technology Intel Wireless WiFi Link 4965AGN (dual-band quad-mode 802.11a/g/N) network connection, supporting Acer SignalUp with InviLink Nplify wireless technology Embedded numeric keypad Bluetooth 2.0+EDR (Enhanced Data Rate) 56K ITU V.92 with PTT approval, Wake-on-Ring ready ExpressCard/54 slot 5-in-1 card reader (SD, MMC, MS, MS Pro, ) Three USB 2.0 ports External display (VGA) port Headphone/speaker/line-out jack with S/PDIF support Weight: 3.4Kg Dimensions: 385 x 277 x 41/43.9mm (W x D x H)
פורסם 2009 באפריל 317 שנים מוגזם לגמרי. לשימושים של סרטים ואופיס אין צורך בכזה מפרט. אפשר להשקיע את התקציב באיכות במקום או לחילופין לרדת במחיר. כמו כן, זה מחשב כבד וגדול, אם אין לך צורך שמחייב נייד כלכך גדול (ולשימושים שציינת בדר"כ אין) הייתי ממליצה לשקול משהו קצת יותר נייד או דסקטופ.
פורסם 2009 באפריל 317 שנים בתקציב כזה אתה יכול להסתכל על מחשבים באיכות מצויינת ועם חיי סוללה טובים יותר וניידות טובה יותר. אפשר להסתכל על ה-Dell E6400 לדוגמא:http://www.notebookclub.co.il/prod-dell-latitude-e6400.htmאו ה-D630. דגם יותר ישן אבל נותן תמורה טובה למחיר ורזולוציה יותר גבוהה. חיי הסוללה יהיו פחות טובים:http://www.notebookclub.co.il/prod-dell-d630-t8100-nvd.htmאם אתה מתעקש (או הקונה מתעקש) על 15.4" ומעלה אז אפשר להסתכל על ה-E5500:http://www.notebookclub.co.il/prod-dell-latitude-e5500.htmה-Lenovo SL500 ב-15.4" זול יותר אך מגיע עם שנת אחריות אחת (ניתן להרחיב) אבל הרזולוציה גבוהה מאד. האיכות כאן טובה מהממוצע אבל לא ברמה של המחשבים האחרים שציינתי. הוא גם מכיל כרטיס מסך נפרד שאין לך בו צורך (בקונפיגורציה עם הרזולוציה הגבוהה):http://www.zap.co.il/model.aspx?modelid=713314יש עוד המון דגמים שיתאימו לדרישות (למעשה כמעט כל הדגמים הקיימים) במחירים נמוכים יותר. ציינתי רק דגמים ששמים דגש על ניצול התקציב לאיכות טובה. כל הדגמים הללו מכילים מסך מט, אם יש העדפה למבריק יהיה צורך להסתכל על משהו אחר, בעיקר מחשבים צרכניים ומספר חצי-עסקיים.
פורסם 2009 באפריל 317 שנים מחבר המחשב יהיה יותר נייח מנייד במקרה הזה וגודלו של המסך צריך להיות גדול (15-17).כמו כן אין בעיה אם המחשב יהיה 3.5 ק"ג אם הוא יהיה בבית רוב הזמן.במה יותר טובים המחשבים הניידים שהצעת מהמחשב שהזכרתי בהודעתי הראשונה?
