Windows XP SP3 PROBLEM
Hey,
I've installed new windows called "Windows XP Performance Edition SP3 // April 2008 // V2".
When i'm trying to add hebrew support(the usual way, going adding the language file from the disk, and then add keyboard set).
I get error at keyboard set called
"Setup was unable to install the chosen locale please contact you Adminstrator".
Is there any possible solution?
(Alternative to windows one, or something).
Thanks.
install a normal windows xp without stupid crap ?
even googling this crap on google shows it has problems with hebrew.
