המסכים הכחולים חזרו ! *עודכן* 20.20
memory corruption לא אומר בהכרח שיש לך תקלה ב-Ram.
זה יכול להיות קשור(בעקיפין) ל-Page File.
תלחץ על analyze -v לקבלת פירוט טכני מעמיק יותר על התקלה.
הינה מה שרשם לי אחרי שלחצתי על הanalyze -v
BugCheck 4E, {99, b1a7, 2, 7b1a6}
Probably caused by : memory_corruption ( nt!MiBadShareCount+24 )
Followup: MachineOwner
0: kd> !analyze -v
* Bugcheck Analysis *
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc). If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 00000099, A PTE or PFN is corrupt
Arg2: 0000b1a7, page frame number
Arg3: 00000002, current page state
Arg4: 0007b1a6, 0
Debugging Details:
BUGCHECK_STR: 0x4E_99
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: firefox.exe
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 820a994b to 820d3163
STACK_TEXT:
96a9d780 820a994b 0000004e 00000099 0000b1a7 nt!KeBugCheckEx+0x1e
96a9d798 820a72f6 c0802000 00000000 874add30 nt!MiBadShareCount+0x24
96a9d7e4 820a77c5 874adb60 85c5ac90 874adb60 nt!MiDeletePfnList+0x36f
96a9dc4c 820a5f4e 874adb60 00000000 00000000 nt!MiDeleteAddressesInWorkingSet+0x31c
96a9dc78 8221508a 2218002f 84b89820 c0000005 nt!MmCleanProcessAddressSpace+0x13a
96a9dcdc 821eb331 00000000 85c5ac90 85c5ac01 nt!PspExitThread+0x65d
96a9dcf4 82048130 84b89820 96a9dd20 96a9dd2c nt!PsExitSpecialApc+0x22
96a9dd4c 8205db26 00000001 00000000 96a9dd64 nt!KiDeliverApc+0x1dc
96a9dd4c 777c9a94 00000001 00000000 96a9dd64 nt!KiServiceExit+0x56
WARNING: Frame IP not in any known module. Following frames may be wrong.
0ad2fb10 00000000 00000000 00000000 00000000 0x777c9a94
STACK_COMMAND: kb
FOLLOWUP_IP:
820a994b cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MiBadShareCount+24
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4812bd71
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: 0x4E_99_nt!MiBadShareCount+24
Use !analyze -v to get detailed debugging information.
אתה לא צריך להראות לי את זה.
כבר ראיתי את זה והצעתי לך פתרונות. אין פה שום פתרון קסם שיפתור לך את הבעיה.
תתחיל בלנסות להסיר ולהתקין מחדש את כל הדרייברים שהתקנת לאחרונה.
רשמתי לך את זה כבר בהודעה הקודמת. אתה לא מתייחס לכל ההודעה בשלמותה ואתה מצפה שהעיה תיפתר מעצמה ::)
בטח שאני מתחיל לעבוד על הפתרונות שלך !! ;D אני ביקשתי עכשיו שם של תוכנה טובה להסיר דרייברים של כרטיס מסך וכד'...
אז אני יתחיל למחוק את כל הדרייברים שהתקנתי ואז יחזיר הכל מאתרים מעודכן !
ד"א תודה רבה מאוד על העזרה שלך...
חג שמח ושנה טובה אני יתחיל למחוק עכשיו ! !
מחקתי את הדרייבר של הכרטיס מסך התקנתי חדש ! מועדכן ! מאתר של ניבידה..
פעם לחבר שלי הייתה את הבעיה הזאת נראלי ואני צריך להוריד מהאתר של היצרן הכרטיס אבל ההורדה לא תקינה לא יודע למה..
נקווה שיסתדר לי !!!
הקפצה...
היום היו לי 2 מסכים כחולים פתואמיים ואני לא מצליח לקרוא..
לא יודע למה
הורדה למטה !!
[attachment deleted by admin]
Probably caused by : ndis.sys
ניסית להסיר ולהתקין את כל הדרייברים מחדש?
שוב אני חוזר ואומר: הבעיה ככל הנראה קשורה לדרייברים(התנגשויות/אי תאימויות בין כתובות דרייברים כאלו או אחרות)
http://eudora.com/techsupport/kb/2291hq.html
http://www.file.net/process/ndis.sys.html
מתן תודה רבה על העזרה..דבר ראשון.
דבר שני : מחקתי את הדרייברים של הכרטיס מסך כבר פעמים ביומיים והתקנתי חדשים !
ועדיין זה ממשיך לקרות...
מצטער על הת'רד בתמיכה טכנית !
ומתן האם פירמוט של הוינדוס יעזור במקרה הזה !?
תאמת אני לא מבין מה אני צריך לעשות כל כך..
אז אם אפשר לדעת מה לעשות ?
למה אתה כ"כ בטוח שהדרייבר הזה קשור לכרטיס מסך?
תיכנס לקישורים שנתתי לך למעלה.
ולפני שאתה עושה צעד כמו פירמוט: תנסה להסיר את כל הדרייברים ביסודיות מהמחשב, ותתקין אותם מחדש.
אוקי מצאתי בתיקיה של וינדוס את הקובץ ndis.sys עכשיו מה אני צריך לעשות לו ? מחיקה ?
