עץ חיפוש בינארי
אני זקוק נואשות לעזרה.. יש לי את הקובץ עץ בינארי הזה שאני אמור להוסיף לו 5 פונקציה ואני דיי אבוד שם....
אני ישמח לקבל איזה עזרה..
// tree node
public class BinarySearchTree {
// tree root
private BSTNode root;
private class BSTNode {
private Object data;
private BSTNode left;
private BSTNode right;
BSTNode(Object newdata) {
data = newdata;
public String toString(){
return "data: "+data+" ";
// compare two objects (integer type)
private static int compare(Object o1, Object o2) {
int ans = 0;
int n1 = ((Number)o1).intValue();
int n2 = ((Number)o2).intValue();
if(n1>n2) ans = 1;
else if(n1<n2) ans = -1;
return ans;
public String getRoot(){
return root.toString();
// insert element to the tree
public void insert(Object elem) {
root = insert(root, elem);
BSTNode insert(BSTNode tree, Object elem) {
int count=0;
if (tree == null) {
return new BSTNode(elem);
if (compare(elem, tree.data) < 0) {
tree.left = insert(tree.left, elem);
return tree;
else{
tree.right = insert(tree.right, elem);
return tree;
// search for element elem
public boolean find(Object elem) {
return find(root,elem);
boolean find(BSTNode tree, Object elem) {
if (tree == null)
return false;
if (compare(elem, tree.data) == 0)
return true;
return find(tree.left, elem);
else
return find(tree.right, elem);
// print all tree nodes
public void print() {
print(root);
System.out.println();
void print(BSTNode tree) {
if (tree != null) {
print(tree.left);
System.out.print(tree.data+",");
print(tree.right);
// delete emement elem from the tree
public void delete(Object elem) {
root = delete(root, elem);
BSTNode delete(BSTNode tree, Object elem) {
if (tree == null)
return null;
if (compare(elem, tree.data) == 0) {
if (tree.left == null)
return tree.right;
else if (tree.right == null)
return tree.left;
else {
if (tree.right.left == null) {
tree.data = tree.right.data;
tree.right = tree.right.right;
return tree;
else {
tree.data = removeSmallest(tree.right);
return tree;
else if (compare(elem, tree.data) < 0) {
tree.left = delete(tree.left, elem);
return tree;
else {
tree.right = delete(tree.right, elem);
return tree;
// function removeSmallest is used from function delete
// to remove the smallest element of the tree
Object removeSmallest(BSTNode tree) {
if (tree.left.left == null) {
Object smallest = tree.left.data;
tree.left = tree.left.right;
return smallest;
else {
return removeSmallest(tree.left);
public Object minimum() {
public Object maximum(){
public int size(){
public boolean isEmpty(){
return this.getRoot() == null;
public Object findNearestSmall(Object elem){
public Object findNearestGrate(Object elem){
ערוך את ההודעה שלך ושים את הקוד בתוך טג קוד, כדי שיראה נורמלי.
minimum:
טרברסל על העץ (לא משנה סוג הטרברסל) ומציאת האיבר המינימלי תוך כדי.
maximum:
טרברסל על העץ (לא משנה סוג הטרברסל) ומציאת האיבר המקסימלי תוך כדי.
size:
טרברסל על העץ (לא משנה סוג הטרברסל) וספירת הצמתים תוך כדי.
findNearestSmall :
שליפת תת העץ השמאלי היוצא מהצומת שקיבלנו כפרמטר מהפונקציה , יש לעשות טרברסל מכל סוג על תת עץ זה ולהחזיר את האיבר הגדול ביותר.
findNearestGrate:
שליפת תת העץ הימני היוצא מהצומת שקיבלנו כפרמטר מהפונקציה , יש לעשות טרברסל מכל סוג על תת עץ זה ולהחזיר את האיבר הקטן ביותר.
אם אתה לא יודע מה זה טרברסל , כנס לפה : http://en.wikipedia.org/wiki/Tree_traversal
אם אתה לא מסוגל להבין מה כתוב בלינק שנתתי לך , פרוש מתכנות ותלך לעשות משהו אחר שאתה כן טוב בו וכן יכול להתפתח בו.
שמח אם עזרתי,
יוסי.
לפרוש מתכנות, קצת הגזמת הייתי אומר, במיוחד כאשר בשביל למצוא את הבן ה MAX, לא צריך לעבור על כל העץ, אלה רק לימני ביותר ( ללכת לבן הימני עד שמגיע לקודקוד שכבר אין לו בן ימני ). כנל עבור MIN, רק שצריך ללכת שמאלה.
גם בשביל שני ה FIND לא צריך לעבור על תתי עצים, אלה רק להחזיר את הבן הימני / שמאלי / אב בהתאם.
בקיצור, יש הבדל בין עץ בינארי, לעץ חיפוש בינארי.
וואו , חשבת כמה שניות יותר ממני והראית לי שיש פתרונות יעילים יותר , מה ניסית להוכיח? כתבתי את הפתרונות שלי בצורה פשטנית בכוונה רק בשביל לא לסבך אותו יותר מידי , מה נדמה לך שאני לא מודע לכך שהפתרונות שלי לא מדויקים או לא יעילים?
נ.ב. : (ולא בנימה צינית) מצטער אם העלבתי מישהו בכך שאמרתי : פרוש מתכנות .
