מחשב חדש HP קיים VISTA להוריד ל XP
שלום לכם
מדובר במחשב חדש של HP דגם a6440.is הגיע עם VISTA רוצה להוריד ל XP אבל לא מצאתי דריברים הלוח אם מיוצר ע"י ASUS
כניראה במיוחד עבור HP ואין דריברים ה VISTA מגיע בתוך המחשב בהרדיסק ,,,כאן למטה מפרט הלוח אולי משהו יכול להציע משהו
Part / Feature Specification / Support
Motherboard description Motherboard manufacturer's name: Asus IPIBL-LB
HP/Compaq name: Benicia-GL8E
CPU/Processor Socket: 775
Supports the following processors:
Core 2 Quad Q9xxx with Quad Core technology
Core 2 Duo E8xxx
Core 2 Quad Q6xx0 with Quad Core technology
Core 2 Duo E6x00
Core 2 Duo E4x00
Front-side bus (FSB) 800/1066/1333 MHz
Chipset Intel G33
BIOS features Keyboard combination to used to enter BIOS: F10
System BIOS core brand: Award
Form factor micro-ATX: 9.6 in X 9.6 in
Memory Dual channel memory architecture
Four 240-pin DDR2 DIMM sockets
Supported DIMM types:
PC2-5300 (667 MHz)
PC2-6400 (800 MHz)
Non-ECC memory only, unbuffered
Supports 2GB DDR2 DIMMs
Supports up to 8 GB on 64 bit PCs
Supports up to 4 GB* on 32 bit PCs
NOTE: *Actual available memory may be less
Expansion slots One PCI
One PCI Express x16 graphics (for graphics cards)
Two PCI Express x1 (for cards such as network, sound, tv-tuner)
Video graphics Integrated graphics using Intel GMA 3100
Also supports PCI Express x16 graphics cards
NOTE: Either integrated graphics or the PCI Express x16 slot are usable at one time; they are not usable concurrently.
Serial ATA Six SATA connectors:
Supports 1 SATA-150 or SATA-300 disk drive on each SATA connector
Speed up to 1.5Gb/sec or 3.0Gb/sec, complying with SATA 1.0 and SATA 2.0 specifications
NOTE: The faster rate of 3.0Gb/sec requires that both the hard drive and the motherboard support it. If one or the other does not support 3.0 Gb/sec, the PC negotiates down to the slower 1.5 Gb/sec.
RAID Onboard RAID controller: ICH9R
Selected Benicia models ship RAID-ready (For Spring 08, only selected CTO models will ship RAID-ready)
RAID modes supported*:
RAID 0
RAID 1
NOTE: RAID 5 requires three HDDs and RAID 10 requires four HDDs. While this motherboard can support RAID 10, only RAID 0 and RAID 1 modes are supported on computer models using this motherboard.
Onboard audio Audio CODEC: ALC888S
7.1 channel high-definition audio
Onboard LAN 1 Realtek 8111C 10/100/1000 Mb/s (Gigabit Ethernet) Integrated LAN
NOTE: Gigabit Ethernet is backwards compatible with 10/100 Mb/s network hardware.
Onboard USB USB 2.0
Twelve ports total
Four connectors on back panel
Six headers (four 1x4 and two 2x5 USB headers) support eight additional USB ports/devices
NOTE: Some USB ports may not be available externally for customer use. For more information, see model specifications.
Onboard 1394 Type: IEEE 1394a 400Mb/s
Agere LFW3227 controller chip
Two ports total
One port on back panel
One header on motherboard supporting one additional port/device
Back panel I/0 One PS/2 mouse port (green)
One PS/2 keyboard port (purple)
One coaxial SPDIF out
One coaxial SPDIF in
One VGA port
Four USB 2.0
One 6-pin IEEE 1394a
One RJ-45 networking port
Six Stereo-mini audio jacks for:
Line-in (light blue)
Microphone-in (pink)
Line-out (lime)
Center/Subwoofer-out (yellow-orange)
Side speaker-out (gray)
Rear speaker-out (black)
Internal connectors One 24-pin ATX power connector
One 4-pin ATX power connector
Six SATA connectors
One floppy drive connector
Two 12v fan connectors for CPU fan and PC fan
One 9-pin header for power button, reset button, power LED, and HDD LED
Three USB 2.0 headers supporting 6 USB ports or devices
One IEEE 1394a header
One SPDIF audio output header
One 4-pin audio line-input connector (interrupts line input on back panel, Vista capable, requires matching front audio jack module)
One 9-pin audio header for headphone-out and microphone-in (yellow, Vista capable, requires matching front audio jack module)
One Intel high-definition Audio/Modem Link (2x8 HDMI connector)
One jumper for resetting BIOS settings
One jumper to disable BIOS password checking
כל מה שהדבקת לא ממש עוזר (וגם היית יכול לפחות ליישר את זה לצד שמאל כדי שזה יהיה קריא).
אתה צריך לבדוק איזה רכיבי חומרה בדיוק יש לך במחשב (ע"י תוכנות לזיהוי חומרה ואז תוכל לדעת מה מצבך לגבי דרייברים לXP.
