מה עושה הקובץ rundll32.exe ?
שלום,
זה תקין שהוא רץ לי מעל 10 פעמים בו זמנית על היוזר שאני עובד איתו במחשב ? (מערכת XP)
ובנוסף מה עושה הקובץ svchost.exe שרץ על SYSTEM ?
תודה!
rundll32.exe is a process which executes DLL's and places their libraries into the memory, so they can be used more efficiently by applications. This program is important for the stable and secure running of your computer and should not be terminated.
Note: rundll32.exe is a process registered as a backdoor vulnerability which may be installed for malicious purposes by an attacker allowing access to your computer from remote locations, stealing passwords, Internet banking and personal data. This process is a security risk and should be removed from your system.
Note: rundll32.exe could also be a process which belongs to the . This program is a non-essential process, but should not be terminated unless suspected to be causing problems.
Determining whether rundll32.exe is a virus or a legitimate Windows process depends on the directory location it executes or runs from.
We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
svchost.exe is a system process belonging to the Microsoft Windows Operating System which handles processes executed from DLLs. This program is important for the stable and secure running of your computer and should not be terminated.
Note: svchost.exe is a process registered as a backdoor vulnerability which may be installed for malicious purposes by an attacker allowing access to your computer from remote locations, stealing passwords, Internet banking and personal data. If unaccounted for, this process should be removed immediately.
Note: svchost.exe is a process which is registered as a trojan. This Trojan allows attackers to access your computer from remote locations, stealing passwords, Internet banking and personal data. This process is a security risk and should be removed from your system.
Note: svchost.exe is a process belonging to Microsoft Service Host Process. This could also be a stealth monitoring software that sits in the background and tracks all activities such as keyboard input (including websites visited, passwords etc.) This information can be sent to third parties through email or ftp uploads. If you did not intentionally install this program make sure you remove it to protect your privacy.
Determining whether svchost.exe is a virus or a legitimate Windows process depends on the directory location it executes or runs from.
We strongly recommend that you run a FREE registry scan to identify svchost.exe related errors.
rundll32.exe
http://www.howtogeek.com/howto/windows-vista/what-is-rundll32exe-and-why-is-it-running/
svchost.exe
http://www.howtogeek.com/howto/windows-vista/what-is-svchostexe-and-why-is-it-running/
שתיהם קבצים נורמלים של המערכת, ושתיהם רצים בד"כ יותר מפעם אחת, אבל תמיד צריך להיות חשדן |:
בכל אופן, יש גם הרבה וירוסים / רוגלות / טרויאנים שאוהבים לנצל את השם של קבצי מערכת שונים. מומלץ בחוםפ להריץ סריקת וירוסים, טרויאנים, רוגלות וכל מה שעולה לך בראש.
ותסרוק גם עם hijackthis ותנתח את ה-LOG באתר www.hijackthis.de ותראה אם יש שם דברים חשודים.
rundll32.exe
svchost.exe
אם יצא הכל וי ירוק וחלק וי ירוק עם חומת אש (FIREWALL) הכל תקין?
לא הבנתי מזה סורק בכלל? זה רק בודק איזה קבצים עובדים במערכת ומוציא לוג רשימה, לא ?
ומה אומר הסימן איקס כתום ?
