bezeqint problems really bad lag?
anyone els have problems with bezeqint
all week i cant even use ventrilo its killing me how bad it lags
ב-Ventrilo באמת יש פינג גבוה (150-200) אבל זה נסבל...
אני משחק גם COH ואין שום לאגים באינטרנט
id be happy with 200ms
but this more like 20.000ms and crashing ever 5 sec
seem to be worst between 4-11pm
bit better after 1am
Same problem here.
They are using traffic shaping and port blocking and thats why Ventrillo lags that bad.
You can try to reset, it seems that there are several routing options that dont have traffic shaping, simply reset until its ok, but usually, when ventrillo works ok, the other latencies are bad, aka 200 and more.
yes , thats what i use to do in the passt
id rest it till vent work and then like world of warcraft will be laging bad
this like i can only use one or the other :( suxs any way
now its not helping at all
here a test i did , this bit long but look at the lower list number 3
u can clerle see the 87% packt lost
in other test i lost 80-100%
and this bzq-115-186-113.static.bezeqint.net thats where the problem seem to be
what ever that thing is
Microsoft Windows XP [Version 5.1.2600]
© Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Administrator>pathping fluorine.typefrag.com
Tracing route to fluorine.typefrag.com [69.12.15.138]
over a maximum of 30 hops:
0 david [192.168.1.55]
1 192.168.1.1
2 * bzq-79-176-137-1.red.bezeqint.net [79.176.137.1]
3 * * bzq-115-186-113.static.bezeqint.net [192.115.186.113]
4 * bzq-179-124-5.static.bezeqint.net [212.179.124.5]
5 bzq-179-124-26.static.bezeqint.net [212.179.124.26]
6 mil8-bi-4.seabone.net [195.22.192.77]
7 decix-fra50-racc2.fra.seabone.net [195.22.211.107]
8 decix.teleglobe.net [80.81.193.114]
9 Vlan79.icore1.NTO-NewYork.teleglobe.net [195.219.180.50]
10 if-12-0-0-13.core2.NTO-NewYork.teleglobe.net [216.6.97.5]
11 if-3-0.core2.CT8-Chicago.teleglobe.net [66.110.14.21]
12 if-5-0-0-718.core2.DTX-Dallas.teleglobe.net [66.110.14.42]
13 ix-7-1.core2.DTX-Dallas.teleglobe.net [66.198.2.18]
14 so-1-2-0.core1.dfw1.netfire.com [69.17.82.158]
15 69.12.15.138
Computing statistics for 375 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% 192.168.1.1
0/ 100 = 0% |
2 10ms 0/ 100 = 0% 0/ 100 = 0% bzq-79-176-137-1.red.bezeqint.net
[79.176.137.1]
0/ 100 = 0% |
3 23ms 87/ 100 = 87% 87/ 100 = 87% bzq-115-186-113.static.bezeqint.ne
t [192.115.186.113]
0/ 100 = 0% |
4 10ms 0/ 100 = 0% 0/ 100 = 0% bzq-179-124-5.static.bezeqint.net
[212.179.124.5]
0/ 100 = 0% |
5 9ms 0/ 100 = 0% 0/ 100 = 0% bzq-179-124-26.static.bezeqint.net
[212.179.124.26]
0/ 100 = 0% |
6 76ms 0/ 100 = 0% 0/ 100 = 0% mil8-bi-4.seabone.net [195.22.192.
77]
0/ 100 = 0% |
7 108ms 0/ 100 = 0% 0/ 100 = 0% decix-fra50-racc2.fra.seabone.net
[195.22.211.107]
0/ 100 = 0% |
8 105ms 0/ 100 = 0% 0/ 100 = 0% decix.teleglobe.net [80.81.193.114
0/ 100 = 0% |
9 188ms 0/ 100 = 0% 0/ 100 = 0% Vlan79.icore1.NTO-NewYork.teleglob
0/ 100 = 0% |
10 168ms 1/ 100 = 1% 1/ 100 = 1% if-12-0-0-13.core2.NTO-NewYork.tel
0/ 100 = 0% |
11 195ms 0/ 100 = 0% 0/ 100 = 0% if-3-0.core2.CT8-Chicago.teleglobe
.net [66.110.14.21]
0/ 100 = 0% |
12 219ms 0/ 100 = 0% 0/ 100 = 0% if-5-0-0-718.core2.DTX-Dallas.tele
0/ 100 = 0% |
13 --- 100/ 100 =100% 100/ 100 =100% ix-7-1.core2.DTX-Dallas.teleglobe.
net [66.198.2.18]
0/ 100 = 0% |
14 190ms 0/ 100 = 0% 0/ 100 = 0% so-1-2-0.core1.dfw1.netfire.com [6
9.17.82.158]
0/ 100 = 0% |
15 198ms 0/ 100 = 0% 0/ 100 = 0% 69.12.15.138
Trace complete.
[/center
