pc for gaming 3.5k
I am going to buy this pc soon from skypc. I am mainly going to use it for gaming (cod4 , crysis, ac) My budget is 3.5k but I am willing to add 100 , 200 shekels if it will improve the system by a lot.
please give me advice on what i should buy and what i should not
thanks
Intel Core 2 Duo E8400 Box
¤992
כמות:1
http://skypc.co.il/product.asp?pid=IE8400
לוח אם GIGABYTE GA-P35-DS3L
¤440
כמות:1
http://skypc.co.il/product.asp?pid=39207
כונן קשיח Western Digital WD2500AAKS 250GB
¤298
כמות:1
http://skypc.co.il/product.asp?pid=2500AAKS
זיכרון Mushkin DDR2 2048MB (1024MBx2) 800Mhz CL 5-5-5-15 SP
¤219
כמות:1
http://skypc.co.il/product.asp?pid=996529
כרטיס גרפי Club3D nVIDIA GeForce 8800GT Heatpipe 512MB PCIe
¤985
כמות:1
http://skypc.co.il/product.asp?pid=CGNX-G882DDC
מארז כולל ספק Enermax Chakra ECA3052 BLUE Liberty 400W
¤617
כמות:1
http://skypc.co.il/product.asp?pid=ECA3052-BL-400
סה"כ מחיר לכל המוצרים:3551¤
Proposed Changes / Recommendations :
Case/PSU : You might consider swapping the Case/PSU to some more earthly combination - and yet of no lesser quality, like the CompuCase 6A19B + HEC 400TR-TF 400W (370 NIS at SkyPC).
CPU Cooler : you might want to pick some better-than-stock CPU Cooler, like the GlacialTech Igloo 5600 w/ PWM Fan (100 NIS at SkyPC).
HDD : Upgrading the HDD to 320GB is nearly a must - where the price is just 50 NIS up from the 250GB.
Thanks for your reply.
1. I decided to buy the chakra case because it has a 250mm side fan. I thought that by buying a case with such a big fan and also considering the fact that I will probably never OC the cpu I would not need to buy a custom cpu cooler. What advantages will I get from a CPU cooler? Will the preformance be better? Will the processor last longer?
BTW the CompuCase 6A19B does look pretty ugly.
2. Yeah I did think of upgrading the HDD, so I will buy a 320GB. What company makes the longest lasting HDD's?
Thanks!
1. I'd advise Against shelling an extra 250 NIS - If it's mostly for getting a "better" Side Fan.
One might better invest in an Improved CPU Cooler (~100 NIS) - for Higher Efficiency (e.g. : Better Cooling & Lower Noise), and in an Addtional 120mm Case Fan (35 to 50 NIS) - for Better Air Circulation.
as for the Design of the CompuCase 6A19B, IMHO - It's Elegant, Functional & Efficient - Anyhow, this is a matter of personal preference.
2. Western-Digital's are The Best in Terms of Reliability & Durablity, IMHO.
מעבד:
INTEL CORE 2 DUO S775 3.0GHz E8400 45nm : " SLAPL" - BOX ¤969
לוח אם:
GIGABYTE GA-P31-DS3L ¤373
כרטיס מסך:
TWINTECH PCI-EX 2.0 GeForce 9600GT 512MB DDR3 - RETAIL ¤750
דיסק קשיח:
SEAGATE BARRACUDA 7200.10 320GB 16MB SATA2 NCQ - ST3320620AS ¤374
צורב DVD:
SAMSUNG SH-S203B x20 SATA BLACK ¤154
זיכרון:
GEIL 2048MB DDR2 ULTRA 800 (1024X2) CL 4-4-4-12 : GX24GB6400C4UDC ¤260
מארז:
ENERMAX CHAKRA ECA3052 (BLACK/SILVER) +25cm FAN w/o PSU ¤307
ספק כוח:
FSP 400W : ATX400-PNR ¤167
קרור למארז:
GLACIALTECH 80mm CASE FAN - SILENT BLADE SLEEVE BEARING 19dBA - BLACK - GT8025EBDL-1 ¤31
הרכבת מחשב:
הרכבת מחשב + בדיקת מאמץ 24 שעות + בדיקות מקיפות ¤0
מחיר סופי: ¤3385
ספק-כוח, מעבד, כרטיס-תצוגה, וכונן-תקליטורים מיטביים - כל השאר לא.
מה רע בדיסק הקשיח?
