פורסם 2008 במרץ 818 שנים המחשב עובד לעט הנה פירוט קבצי מינידאמפ Microsoft ® Windows Debugger Version 6.8.0004.0 X86Copyright © Microsoft Corporation. All rights reserved.Loading Dump File [C:\WINDOWS\Minidump\Mini030708-02.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: C:\Documents and Settings\edi\Desktop\WindowsXP-KB835935-SP2-Debug-slp-Symbols.exeExecutable search path is: Unable to load image ntoskrnl.exe, Win32 error 0n2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeWindows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSKernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700Debug session time: Fri Mar 7 07:35:08.531 2008 (GMT+2)System Uptime: 0 days 0:11:09.153Unable to load image ntoskrnl.exe, Win32 error 0n2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeLoading Kernel Symbols...Loading User SymbolsLoading unloaded module list.............******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 1000000A, {905f0008, 2, 1, 805229eb}*** WARNING: Unable to verify timestamp for mssmbios.sys*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys***** Kernel symbols are WRONG. Please fix symbols to do analysis.**************************************************************************** ****** ****** Your debugger is not using the correct symbols ****** ****** In order for this command to work properly, your symbol path ****** must point to .pdb files that have full type information. ****** ****** Certain .pdb files (such as the public OS symbols) do not ****** contain the required information. Contact the group that ****** provided you with these symbols if you need this command to ****** work. ****** ****** Type referenced: nt!_KPRCB ****** ******************************************************************************************************************************************************** ****** ****** Your debugger is not using the correct symbols ****** ****** In order for this command to work properly, your symbol path ****** must point to .pdb files that have full type information. ****** ****** Certain .pdb files (such as the public OS symbols) do not ****** contain the required information. Contact the group that ****** provided you with these symbols if you need this command to ****** work. ****** ****** Type referenced: nt!_KPRCB ****** ****************************************************************************Probably caused by : ntoskrnl.exe ( nt+4b9eb )Followup: MachineOwner---------
פורסם 2008 במרץ 818 שנים תתקן את הגישה לסימבולים או שתשתמש בסיבולים אונלייןותיישר את הטקסט לשמאלבכל אופן אין שום קשר בין איטיות ומינידאמפס,המינידאמפ נוצרים ומדווחים רק על תקלות שגרמו למסך כחול ו\או ריסט.
פורסם 2008 במרץ 818 שנים Your debugger is not using the correct symbolsכמו שאמר רועי , תתקן את הPATH כלומר הדרך או המקום האמיתי של הSYMBOLSאם יש לך איטיות במחשב , תעשה 1)סריקה של וירוסים ורוגלות2)ניקוי הארד דיסק 3)תעשה איחוי דיסק
