המתאבק chris benoit רצח את אישתו והילד שלו והתאבד
טוב זה לא נישמע כמו עוד סיפור עלילה מהWWE
כמו הסיפור של וינס מקמאן שבטח לוגם שמפניה באיזה חור עד שיופיע מיחדש
הסיפור על קריס כניראה אמיתי וזה מה שהיה כתוב -
Benoit's death part of a double murder-suicide
Written: June 25, 2007
According to lead investigator Lt. Tommy Pope, of the Fayette County Sheriffs Department, in Fayetteville, Ga., the deaths of WWE Superstar Chris Benoit, wife Nancy and son Daniel were the result of a double murder-suicide, WWE.com has learned.
Benoit failed to appear both at Saturdays live event in Beaumont, Tx., and WWEs Vengeance: Night of Champions in Houston Sunday night, after informing WWE of a family emergency. Several curious text messages sent by Benoit early Sunday morning prompted concerned friends to alert Richard Hering, VP of Government Relations for WWE, Inc. Hering, in turn, spoke with Fayette County sheriffs Monday, and requested that they respond to the Benoit residence to check on him and his family.
Authorities representing the Sheriffs Department initially had a difficult time entering Benoits new Fayetteville home Monday afternoon, which had been guarded by two large German Shepherds roaming freely around the property. Once authorities entered the residence, they quickly located the bodies of Benoit, Nancy and Daniel. WWE was notified of the discovery at approximately 4 p.m.
At 10 p.m. Monday night, Lt. Pope held a press conference in conjunction with Scott Ballard, the district attorney for Fayette County. The press conference officially ruled authorities findings as a double murder-suicide from within the home.
WAGA, a FOX-owned and operated television station in Atlanta, reported that investigators believe Benoit killed his wife and 7-year-old son over the weekend, then himself on Monday.
The three bodies have been received by the Georgia Bureau of Investigations crime lab, in Decatur, Ga., where autopsies will be performed Tuesday morning. Toxicology reports will not become available for at least two weeks.
WWE.com has further information relating to both the investigation and the cause of death, but the Fayette County Sheriffs Department has requested that WWE.com not release any additional details at this time.
http://www.wwe.com/shows/ecw/superstars/chrisbenoit/articles/benoitupdate
וזה הרגשה מוזרה איך לעזזל אפשר ביכלל להרגיש עצב על רוצח שמת?
וואו זה מעניין.
WWE.CO.IL יש שם אינפורמציה בעברית.
חוץ מזה למה לעזעזל הוא יהרוג את אשתו,יום אחרי זה את הילד שלו ואז יום אחרי את עצמו :kopfpatsch::bash: :s05: :nixweiss:
תיראה אמרו שמצאו תגופות
לא היה צילומים של זה שזה קרה ואין לזה אף הגיון עלילתי
כי מוות כזה לא יתן להם ריטינג
בסיפור של וינס היה פיצוץ מצולם לא הראו אף גופה ולא אמרו שמצאו גופות ביכלל
וכל הזמן מצלמים ומפרסמים דברים על זה
ככה שבוינס זה די בטוח עלילה לאומת זאת בקריס זה יותר דומה לבאם באם\יוקוזונה \אנדרי הענק\ וכו
בקיצור מיקרה אמיתי לגמרי
On June 11, 2007, WWE aired a segment at the end of RAW that featured McMahon entering a limousine moments before it exploded. The show went off-air shortly after, and WWE.com reported the angle within minutes as though it were a legitimate occurrence, proclaiming that McMahon was "presumed dead."[5] Although this was the fate of the fictional "Mr. McMahon" character, no harm came to the actual person (the "presumed death" of Mr. McMahon was part of a storyline).[6][7] WWE had acknowledged to CNBC that he was not truly dead.[8]
The June 25th, 2007 edition of RAW was scheduled to be a three-hour memorial to "Mr. McMahon". However, due to the actual sudden death of Chris Benoit, the show opened with Vince McMahon appearing in the empty arena, and acknowledged that his reported death was only of his character as part of a storyline.[9] This was followed by a tribute to Benoit that filled the three-hour timeslot.[10] Because of the deaths of Chris Benoit, his wife Nancy, and their son Daniel, the company decided to end the "Death of Mr. McMahon" Storyline, and all references to this angle (including the sale of an "I did it" T-Shirt) were removed from WWE.com after RAW went off the air that night.
עומרי אתה מעודכן יותר מימני :lol: :lol: :lol:
אני לא צופה יותר אפילו בPFV ורק רואה עידכונים באתר למיקרה שאיך שהוא משהו ישתפר שם
הסיפור אם וינס היה דפוק לגמרי וגם כל העלילות האחרות
פשוט צל למה שWWE היו פעם
אני לא מעודכן, ויקיפדיה מעודכנת
הסיפור עם מקמן היה שקוף מדי, כתבתי שזה היה מבוים באשכול הקודם- וצדקתי.
הסיפור עם כריס בנואה אמיתי, דווח ב CNN ובשאר הרשתות
אלוהים יודע מה לעזאזל הלך שם.
קרירין, תשנה את הכותרת ל"התאבד", זה מציק.
אתה יכול לפרט בקצרה? מה? למה? איך? ומי?
מקמן- דווח שהוא מת בפיצוץ של מכונית
אבל לא היו פרטים, לא נמצאה גופה כמובן, וזה לא דווח בחדשות, אלא רק במקורות של WWE.
בנואה- דווח ב CNN- נכון לעכשיו משערים שהוא רצח את בני משפחתו ואז התאבד, אין בדיוק הרבה מידע על זה כרגע.
אני לא רואה ולא מתעניין בחרטה הזו, נתקלתי בדיווחים תוך כדי שנכנסתי לראות מה חדש.
כריס בנואה? מה לעאזאזל.. ::)
טוב אכן כן, הוא לא יותר בחיים. אני זוכר אותו לפני הרבה שנים שראיתי אותו מתאבק, יהי זכרו ברוך. (במידה ולא רצח את אשתו ובנו)
לפי מה שראיתי בחדשות זה לא בטוח שהוא רצח את המשפחה שלו, זה הכל עדיין בחקירה - למרות שזה הוא כנראה, איפשר לדעת..
http://www.one.co.il/cat/articles/article.aspx?id=94287&bz=9
הוא אחת הדמויות שהכי אהבתי.
בתקופה(שנה-שנתיים) האחרונה פשוט עשו ממנו צחוק מבחינת הסטוריליין
וקראתי שמועות שזה מתסכל אותו מאוד, עד לרמה שהוא איים לעזוב לTNA.
כבר הרבה זמן אני לא עוקב אחרי העלילה של הWWE, אבל המוות שלו נורא
מפתיע :-\
גם אם הוא רצח את אישתו והילד שלו, אני לא יכול לשפוט אותו אלא רק לרחם
עליו ויותר מזה על הילד שלו ואישתו.
וואו זה מעניין.
בטח מעניין, עכשיו יש לי על מה לכתוב !!! דבר איתי דחוף דחוף במסן :cool2:
העלילה של הWWE כבר שנים יותר תומכת בצעירים
ומזלזלת בוותיקים
כניראה הצעירים זולים הרבה יותר ומוכנים לעשות הרבה יותר בישביל הכסף
אבל זה גם דופק תהצגה כי הוותיקים הכי מענינים ודוחקים אותם לצד
קחו לדוגמה תקברן נתנו לו תחגורה ממש לפני פרישה לאומת סינה דמות בינונית ומטה שכבר טונה זמן אם אליפות
למרות שהוא דמות משעממת
