how to boot faster?
how can I omit the the windows logo, so I can reduce the boot delay?
does any-1 know other ways of making the boot process faster?
יש תוכנה הנקראת BootVis. היא אמורה לשפר את מהירות עליית הווינדוס...
לחלק היא באמת משפרת, ולחלק לא... בכל אופן אני ממליץ לך להשתמש בה.
אני מאמין שאחרי חיפוש קצר בגוגל תמצא את התוכנה...
בהצלחה!
Thx, but I have windows 98 SE. BootVis is compatible only for WinXP
than i have no idea... defragging your hard drive may improve the boot time a little bit
some defragment programs even allow you to "put" boot files at the beggining of the hard drive
i use O&O Defrag Server Edition but im not sure if it can work on win9x
search for it in google
Thank you Ariel! I'll try it. But once again, I know [glow=red, 2, 300]there is a way to cancel the Windows logo [/glow] when the computer boots. That "saves" you about 15 seconds - and that''s what I'm lookin' for...
I believe
this is what you are looking for ;)
Edit: I realize this is for Windows XP, but I reckon it should be the same routing for Windows 9x
Edit #2: Ok, so apparently it's not the same routine for Windows 9x
:PThis, however, should work
try to edit the io.sys file , you should have there some option like logo=1 or =0 , put it to 0 & see check it out . should work , i think .
Thanks a lot - it works.
here's how:
You open the Msdos.sys (make sure it's not read only) with the notepad. Then, under where it says [options]
you have to write:
Logo=0
[shadow=blue, 2, 300]That's it![/shadow]
