זיכרון נייד בויסטה!
האם זה נכון שמחברים disk on key למשחב זה מוסיף זיכרון לזיכרון הראשי?
ככה אומרים
כן אפשרי, הינה מאמר על זה>
http://www.tomshardware.com/2007/01/23/countdown_to_windows_vista/page7.html#readyboost
ReadyBoost is designed to help computers with a small amount of main memory. If you add a USB Flash memory device, Windows is capable of adding its storage capacity as physical memory to complement the main memory. Microsoft says that ReadyBoost is safe: you can remove the memory device at any time. It works in conjunction with SuperFetch, buffering frequently used application data onto the memory stick. While we don't believe that this will help much if you have 2 GB or more of RAM, it could be a blessing for computers with only 512 MB or 1 GB of RAM, because 1+ GB of memory is what SuperFetch needs to be efficient. The recommendation is to add roughly as much USB Flash memory as your main memory size.
אתה יכול להראות לי תמונה שממש זה מוסיף לזיכרון הראשי...
