עזרה בבחירת UPS
שלום אני מעוניין לרכוש UPS למערכת הבאה, השאלה איזה מומלץ.. :
Field Value
Computer
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name DIMATEOS-C3F8A6
User Name Admin
Motherboard
CPU Type AMD Athlon 64, 2000 MHz (10 x 200) 3200+
Motherboard Name Abit AN8 / Fatal1ty AN8 Series
Motherboard Chipset nVIDIA nForce4, AMD Hammer
System Memory 1024 MB (PC3200 DDR SDRAM)
BIOS Type Award (07/21/05)
Communication Port NetMos PCI ECP Parallel Port (LPT3)
Display
Video Adapter RADEON X800GT Secondary (256 MB)
Video Adapter RADEON X800GT (256 MB)
3D Accelerator ATI Radeon X800 SE PCI-E (R423)
Monitor Samsung SyncMaster 730B (Digital) [17" LCD] (HVEYC00389)
Multimedia
Audio Adapter nVIDIA MCP04 - Audio Codec Interface
Storage
IDE Controller NVIDIA nForce4 ADMA Controller
IDE Controller NVIDIA nForce4 Parallel ATA Controller
SCSI/RAID Controller SCSI/RAID Host Controller
Floppy Drive Floppy disk drive
Disk Drive WDC WD800JB-00ETA0 (74 GB, IDE)
Disk Drive WDC WD1600JS-60MHB1 (149 GB, IDE)
Optical Drive _NEC DVD_RW ND-3540A (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW)
Optical Drive HL-DT-ST CD-RW GCE-8526B (52x/32x/52x CD-RW)
Optical Drive MP1393S SPW726K SCSI CdRom Device
SMART Hard Disks Status FAIL
Partitions
C: (NTFS) 29996 MB (20541 MB free)
D: (NTFS) 39997 MB (23279 MB free)
E: (NTFS) 42625 MB (23458 MB free)
F: (NTFS) 39997 MB (14557 MB free)
I: (NTFS) 38146 MB (7216 MB free)
J: (NTFS) 38162 MB (21622 MB free)
Total Size 223.6 GB (108.1 GB free)
Input
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Network
Network Adapter NVIDIA nForce Networking Controller - Packet Scheduler Miniport
Network Adapter Realtek RTL8139 Family PCI Fast Ethernet NIC (192.168.2.103)
Peripherals
Printer HP DeskJet 695C
USB1 Controller nVIDIA MCP04 - OHCI USB Controller
USB2 Controller nVIDIA MCP04 - EHCI USB 2.0 Controller
כולל מסך? אם כן איזה מסך?
איזה ספק כוח?
מומלץ לא ג'נרי
לרב מסכים באים עם מיצב פנימי בלי סוללה כך שלא חובה על למסך אבל אם אתה כבר קונה לדברים שכוללים אפסקות חשמל אז כדאי גם למסך כי איך תראה בלי מסך ?
כמו שכתוב:
מסך: Monitor Samsung SyncMaster 730B (Digital) [17" LCD]
ספק: 400W HEC
600VA ומעלה יספיקו
אבל הזולים היום מתחילים מ-650VA
אז שיהיה 650VA
השאלה איזה.. אני גם יכול לקנות 1200 ב-250 שקל:
מייצב מתחוAVRPRO1200ו
יצרן: Advice , סוג: מייצב מתח , מתח: 1200 VA, כיבוי אוטומטי: מבצע כיבוי אוטומטי מפרט מלא...
אני פשוט לא מבין בזה יותר מדי, אני רק צריך שלא ישרף המחשב..
AVR (מייצב מתח) הוא לא UPS (אל פסק)
למעשה UPS מכיל בתוכו AVR כדי לייצב את המתח, ומצבר כדי לספק חשמל
AVR כולל רק את ה-AVR ואין לו מצבר
"SMART Hard Disks Status FAIL"
זה לא נשמע טוב.
תעשה גיבוי למידע שלך דחוף כי זה נראה כאילו ההארד דיסק שלך על סף קריסה.
יכול להיות שאני לא קורא את זה נכון אז ליתר בטחון תכנס לאתר הייצרן שלך ותחפש תוכנה שבודקת את ההארד דיסק. אם באמת יש לך SMART failure אז כנראה עומד ללכת לך הדיסק.
בקשר לUPS
אני קניתי 1000VA של איתן הנדסה. בינתיים הוא עובד יפה (חודש) ועבר בשלום 2 הפסקות חשמל ופריקה מוחלטת של הסוללה שלו.
אני מרוצה בסה"כ, יש לו זמן עבודה ארוך על הסוללה והוא מחזיק בכיף את המחשב שלי והמסכים שלי.
הוא מגיע עם תוכנה שמכבה את המחשב במידה ויש הפסקת חשמל ממושכת ולאחר מכן מכבה את הUPS כדי לשמור על הסוללה.
שמעתי הרבה המלצות על UPS שונים של advice.
בכל מקרה, כמו עם כל מכשיר, אל תקנה את ההכי זול אלא אם כן אין לך כסף כי זה יעלה לך בהמשך.
רוב האתרים ממליצים על 30% הספק יותר מהצריכה של המחשב. הרבה אנשים חושבים שזה יותר ממה שצריך. מבחינתי, הפרש המחירים לא היה גדול מידי אז לא לקחתי סיכון (אם לא יהיה לך מספיק הספק אז הUPS פשוט לא יחזיק את המערכת ותצטרך להפעיל אותו בלי מסך. אגב, בדרך כלל לא בעיה כי יש תוכנה שתכבה את המחשב במקרה שהסוללה מתרוקנת).
יש כמה סוגי UPS:
offline, line interactive and online
כשאון-ליין הכי יקר וצורך הכי הרבה אנרגיה.
תחפש UPS שאפשר לשלוט עליו מהמחשב, יש לו מייצב מתח, יש לו כפתור בדיקה, הוא משמיע אזעקה כשיש בעיה ויש לו אחריות ארוכה. רצוי עם חיבור USB אבל גם סריאל או רשת זה בסדר.
שים לב שרוב ה UPS לא מתאימים למדפסות וסורקים ומכשירים שיש להם מנועים.
חשוב לשים לב לסוג הגל שמוציא הUPS כשגל סינוס הוא הכי טוב.
כל אל פסק חייב להוציא גל סינוס
זרם מתחלף אני מבקש, או בקיצור AC, ולא ראיתי שום אל פסק שמוציא זרם ישר (DC).
הלוואי עלינו....
רק היקרים מייצרים גל סינוס טהור ובדרך כלל אלה ה online בהרבה offline יש squarewave
http://www.pcguide.com/ref/power/ext/ups/funcOutput-c.html
עריכה: אגב, האתר הזה זה סתם הדבר הראשון שעלה בגוגל. הסתכלתי עליו קצת ויש בו מידע מצויין למתחילים לגבי UPS
אם כבר נכנסנו לדקויות זה "מתח חילופין" ולא זרם חילופין (שהיה מתייחס לזרם באמפרים)
ומסכן הספק כוח שיקבל איזה 24V DC במקום 220V AC
הלוואי עלינו....
מה שמילה אחת קטנה עושה
ההבדל בין המשפט ללא המילה "טהור" ובין המילה "טהור"
משמעויות שונות לגמרי
אני דברתי על הזרם מבחינת כיוון, כמו מים שזורמים, לא זרם מבחינת המושג (אמפר).
תסביר בבקשה
כי לא משנה איך תסתכל על squarewave הוא לא סינוס
בילבולציה הכי טוב תמליצו לו דגם וזהו
מה שמתאים לו ואז תמשיכו לדסכס AC/DC חח
