hebrew in an english xp sp2 version
i have done a terrable mistake and installed a pirate copy of windows xp.
not only it wasnt original, it was also moded...
so now- i dont have hebrew in my system - i have installed the "hebrew lang pack"
and still i dont have hebrew keyboard option
and i have question marks insted of hebrew noted in some programs - but when i try to fix it
regional options - and to change the non unicode into hebrew
the message "windows cannot install what u requsted" comes up...
so can someone please please help me fix it all?!?!
1. from where do i get hebrew keyboard layout files ?
2/ howdo i install them?
3. how can i fix the question marks??
try to use "system restore" but i think the new copy of your current version erese the older one so all you can do right now is to make all athe insallation from the begining
and for next time .... dont ever try to make something so criticle to your comp when you dont know how its gonna end
isnt there anything alse i can do ??
i new i was going down, but it was either that, or buying a genuine copy of XP - not even an option at there rates...
so for now, cant i download a file or install a software to fix all this shit???
it realy sucks to have all the system in hebrew but to be unabled to write in hebrew...
another problem is that i cant even get my MSN messenger to work!! but thats the smallest of all problems...
is it o.k. to ask here to a torrent for a normal XP SP2 Hebrew windows version??
if not, can someone mail it to me?
You can buy a second-hand license for WinXP, in ebay (for instance) for very cheap prices...
that still wont solve the problems i have now...
i will consider it...
allthough i dont rush in buying things from the Net...
i had a screw-up the last time... and i have learnd my lesson!
thanks for trying thoug...
