מה עושה התכנית mdm.exe ? כל פעם היא נטענת לי מחדש בלי שביקשתי ממנה.
הי!
יש לי WinMe. מידי פעם אני רואה שהקובץ הנ"ל נטען לזיכרון. כשאני מעיף את ה-Task, לא נראה שזה משפיע על משהו.
למישהו יש רמז מה הקובץ הזה עושה?
בתודה מראש, TheTech. ???
צר לי לשמוע שיש עוד אנשים עם WindowsME .
ועכשיו להסבר:
Machine Debug Manager (MDM.EXE) probably can be found in your Windows directory or your Windows\System directory. It's part of your operating system. You may not need it -- it is a "Script Development Utility", so unless you're writing scripts you probably don't need it -- but removing it is tricky. Instructions for removing it can be found at http://www.forrestandassociates.co.uk/pcforrest/mdm.html. You may want to remove it, because it has a bug that can be annoying. On some computers, it runs fairly often, whether you want it to or not. (It's invisible. To find out whether it's running, press CONTROL-ALT-DELETE and see the list of programs that are running.) Whenever it's running, the other stuff that you're doing may slow down. Moreover, each time it runs, it creates a couple of zero-byte trash files and leaves them in the Windows directory; those just stay there forever or until you delete them. When you have accumulated a few hundred of those trash files, or a few thousand, they will start slowing down your computer's access to other, more useful programs in the Windows directory. -- Don't worry, Forrest's removal instructions are all reversible, so you can get MDM.EXE back later if you ever decide you want it.
לקוח כאן
