פורסם 2006 במרץ 3120 שנים מישהו יכול לבדוק לי בבקשה למה המחשב שלי מקבל מסכים כחולים בוינדוס בלי שום פעולה ? תודה לעוזרים קובץ מצורף עריכה : DUMPLoading Dump File [C:\WINDOWS\Minidump\Mini033106-01.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: *** Invalid ******************************************************************************** Symbol loading may be unreliable without a symbol search path. ** Use .symfix to have the debugger choose a symbol path. ** After setting your symbol path, use .reload to refresh symbol locations. *****************************************************************************Executable search path is: ********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeWindows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSKernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700Debug session time: Fri Mar 31 13:35:20.281 2006 (GMT+2)System Uptime: 0 days 0:00:18.984********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeLoading Kernel Symbols...........................................................................................................................Loading unloaded module list..Loading User SymbolsUnable to load image Ntfs.sys, Win32 error 2*** WARNING: Unable to verify timestamp for Ntfs.sys*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 24, {1902fe, f78bea7c, f78be778, 804fcbc9}***** Kernel symbols are WRONG. Please fix symbols to do analysis.Probably caused by : Ntfs.sys ( Ntfs+65ee )Followup: MachineOwner---------[attachment deleted by admin]
פורסם 2006 באפריל 120 שנים אוקיי ממה שקראתי בפורומים וממה שאני מסיק אז יכול להיות 2 דברים, קודם כל תעדכן את ככללל הדרייברים אצלך כי הבעיה היא באחד מהםדבר שני כניראה והבעיה היא בהארדיסק (ממה שקראתי בפורומים) נסה להריץ CHECK DISK וגם DEFRAG לכוננים
פורסם 2006 באפריל 120 שנים מחבר אני חייב לדעת בוודאות כי יש לי אחריות עשיתי במהלך הלילה בדיקה לזיכרונות עם MEMTEST למשך 8:30 שעות ולא הייתה שגיאה אחת אני אחרי פורמט ז'א שהורדתי את כל הדרייברים הכי מעודכנים שיש
