Problam connecting cd-rom
I wanted to change my cd-rom cause mine wasn't working proparly so I took my sisters' and pluged it in but the windows won't recognize it... what's the problam :s05:
תוודא שחיברת את הכל נכון !
יש חשמל ?
הכונן מקבל מתח?....הנורה של הסידירום דולקת?
I plugged everything in just like it was in the old one...
The cd-rom is getting power and opens, I put a cd in and nothing happens...
I don't even see an icon in "my computer"... I have no idea what happened.
א) תבדוק שהוא מגומפר נכון מאחורה (SLAVE/MASTER).
ב) תבדוק ב CONTROL PANEL ב DEVICE MANAGER האם הוא מופיע עם סימן קריאה צהוב.
It is configured as master but it won't even appear in the device manager... :s05:
and in the bios?
I didn't check...
good for you...
so check that way you can see if it's a hardware or software issue
