hijackthis log.. please help...
the computer got SUCKS .. i cant play anything even icq....
it says i dont have enough virtual memory.. and i have a gig... + 100-500 defined in the virtual configurations.
WHAT SHOULD I DO ?
SORRY ... FORGOT THE LOG...
Logfile of HijackThis v1.99.1
Scan saved at 15:51:56, on 17/11/2005
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Sygate\SPF\smc.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Winamp\winamp.exe
C:\Program Files\ICQ\Icq.exe
C:\PROGRA~1\MOZILL~1\FIREFOX.EXE
D:\hijackthis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.p2p-load.de/share
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://www.p2p-load.de/share
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.hwzone.co.il/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O4 - HKLM\..\Run: [smcService] C:\PROGRA~1\Sygate\SPF\smc.exe -startgui
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O9 - Extra button: ICQ Pro - {6224f700-cba3-4071-b251-47cb894244cd} - C:\PROGRA~1\ICQ\ICQ.exe
O9 - Extra 'Tools' menuitem: ICQ - {6224f700-cba3-4071-b251-47cb894244cd} - C:\PROGRA~1\ICQ\ICQ.exe
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.com/v5consumer/V5Controls/en/x86/client/wuweb_site.cab?1095603027449
O17 - HKLM\System\CCS\Services\Tcpip\..\{B185E86C-47FF-4453-B2D6-322B19D09ADA}: NameServer = 212.150.49.10 206.49.94.234
O20 - Winlogon Notify: WRNotifier - WRLogonNTF.dll (file missing)
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: Sygate Personal Firewall Pro (SmcService) - Sygate Technologies, Inc. - C:\Program Files\Sygate\SPF\smc.exe
הדברים היחידים שאני רואה שיכול להיות הבעיה:
1 תבטל את האנטי :
חסר לו קבצים והוא עדיין רץ, אין ספק שהוא גורם לבעיה (במיוחד הweb scanner (חרא דבר...)
2.אתה מריץ FW של sygate , תבדוק שאתה גם לא מריץ את הFW של XP במקביל זה גם יכול להיות הבעיה
תבטל את שניהם לבדיקה
אין לך רוגלות. (חוץ משני הדרייקים)
אבל יכול להיות שאתה רוצה את זה....
4. זה מתריד אותי:
אני יבדוק ויחזור עליך.
טוב חזרנו...שיחקת כנראה עם הזיכרון של WINDOWS - עד שתלמד על העניין שני מציע שתחזיר למקום , שהwindows ינהל את השיט שלו לבד.
דבר נוסף למי שרוצה לבדוק שהכול תקין אצלו יכול להעביר לאתר הזה את הלוג שלו ובאפון אוטומטי הוא מראה בעיות וזה מסודר תוך כמה שניות
http://hjt.iamnotageek.com/
What are the accurate values for the virtual memory ?
יעזור אם תתן לנו את כמות הRAM שיש לך .
giga
יופי
לא יודע למה זה הכניס את אותה תמונה פעמיים אבל תתיחס רק לאחד מהם :smile1:
[attachment deleted by admin]
Thanks a lot !
Can you give me recommendation for a good antivirus ?
AVG or kapersky my personal opinion
all other sucks or they are to heavy
Thnaks bro !
