שאלה אלו הפרמטרים של המחשב עושה רושם שהוא רותח מה לעשות.
SiSoftware Sandra
Mainboard
Manufacturer : Gigabyte Technology Co., Ltd.
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : GA-7VT600 1394
System BIOS : 06/20/2003-KT600-8237-6A6LYG0SC-00
Chipset : VIA KT400/A, KT600
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 768MB
Bank0/1 - A0 : Empty
Bank2/3 - A1 : DIMM 256MB @ 400Mt/s
Bank4/5 - A2 : DIMM 256MB @ 400Mt/s
Chipset 1
Model : Giga-Byte Technology VT8377 Apollo KT400/A/600 CPU to PCI Bridge
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 2x 167MHz (334MHz data rate)
Maximum FSB Speed / Max Memory Speed : 2x 200MHz / 2x 200MHz
Width : 64-bit
IO Queue Depth : 4 request(s)
Chipset 1 Hub Interface
Type : V-Link
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Speed : 8x 66MHz (528MHz data rate)
IO Queue Depth : 9 request(s)
Logical/Chipset 1 Memory Banks
Bank 2 : 256MB DDR-SDRAM 2.5-2-2-6CL 1CMD
Bank 4 : 256MB DDR-SDRAM 2.5-2-2-6CL 1CMD
Bank Interleave : 4-way
Multiplier : 1/1x
Width : 64-bit
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 0.03
Speed : 16MHz
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module(s)
Memory Module 2 : Kingston 8E04CEEA 256MB 8x(32Mx8) DDR-SDRAM PC3200U-333-650 (CL3 up to 200MHz) (CL2.5 up to 167MHz) (CL2 up to 133MHz)
Memory Module 3 : Kingston 8F04E4EA 256MB 8x(32Mx8) DDR-SDRAM PC3200U-333-650 (CL3 up to 200MHz) (CL2.5 up to 167MHz) (CL2 up to 133MHz)
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 40.0°C / 104.0°F
CPU Temperature : 70.0°C / 158.0°F td
Power / Aux Temperature : 46.0°C / 114.8°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 2909rpm
Voltage Sensor(s)
CPU Voltage : 1.68V
Aux Voltage : 1.33V
+3.3V Voltage : 3.26V
+5V Voltage : 4.60V
+12V Voltage : 12.48V
Standby Voltage : 5.00V
AGP Bus(es) on Hub 1
Version : 3.05
Multiplier : 1/2x
Fast-Writes Enabled : Yes
Isochronous Mode Enabled : No
Addressing Enabled : 32-bit
Aperture Size : 128MB
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (33MHz)
Multiplier : 1/5x
LPC Hub Controller 1
Model : Giga-Byte Technology VT8237 PCI to ISA Bridge
ACPI Power Management Enabled : Yes
Multiplier : 1/4x
Speed : 8MHz
DMA Multiplier : 1/2x
DMA Speed : 4MHz
USB Controller 1
Model : Giga-Byte Technology VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : Giga-Byte Technology VT6202 USB 2.0 Enhanced Host Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 8
Companion Controllers : 4
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
FireWire/1394 Controller 1
Model : Giga-Byte Technology VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
Version : 1.00
Interface : OHCI
Enhanced Support : No
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : VIA VT823x SMBus
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
Speed : 16kHz
Expansion Slot(s)
PCI (9h) : PCI 32-bit +5V +3.3V PME Full-Length Available
PCI (Ah) : PCI 32-bit +5V +3.3V PME Full-Length Available
PCI (Bh) : PCI 32-bit +5V +3.3V PME Full-Length Available
PCI (Ch) : PCI 32-bit +5V +3.3V PME Full-Length Used (Ralink Technology Corp ??? (0201))
PCI (Dh) : PCI 32-bit +5V +3.3V PME Full-Length Available
AGP (8h) : AGP 32-bit +5V Full-Length Used (CardExpert Technology ??? (00F2))
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
Keyboard : Keyboard - None / PS/2
PS/2 Mouse - Detected : Mouse - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
SANDRA היא לא התוכנה הכי טובה לבדוק טמפ' . מה רשום לך בביוס ?
חוץ מזה איזה מעבד יש לך ?
