מסך כחול במהלך עבודה בתוכנת עריכת סרטים
שלום!
במהלך עבודה בתוכנת פינקל סטודיו 9 וגם ביוליד 8 קיבלתי מסך כחול ובו כתוב:
A problem has been detected end windows has been shut down to prevent damage to your computer. The problem seems to be caused be the following file nv_disp. If this is the first time youve seen this stop error screen restart your computer. If this screen appears again follow these steps:the dvice driver got stuck in an infinite loop.
This usually indicates problem with the device itself or with the device driver programming the hardware. Incorrectly please check with your hardware device vendor for any driver updates.
Technical information:
***stop:0x000000ea(0x85aeab80,0x86567d580xf7c5ecbc,0x00000001)
Nv4_disp
Beginning dump of physical memory physical memory dump complete contact your system administrator or technical support group for furtner assistance.
מה אומרת שגיאה זו?
יש פיתרון?
תודה!
נסה את זה.
