אשלייה עצמית ועובדות סלקטיביות
בדיוק עכשיו סיימתי לקרוא מאמר במגזין אינדימדייה ע"י אחד "לב גרינברג", ד"ר ומרצה בבן-גוריון, שטוען ש
Even when Arafat declared a ceasefire on December 16th (2001), the US ignored it, and when Israel breached the ceasefire by assassinating Raad Carmi on January 14th (to avoid the upcoming political negotiations)
ומצד שני קצת פרספקטיבה היסטורית מאתר משרד החוץ, למי שיש קצת יכולת למחשבה עצמית ולא קונה כל מה שאומרים לו:
Dec 12, 2001 - Yair Amar, 13, of Emmanuel; Esther Avraham, 42, of Emmanuel; Border Police Chief Warrant Officer Yoel Bienenfeld, 35, of Moshav Tel Shahar; Moshe Gutman, 40, of Emmanuel; Avraham Nahman Nitzani, 17, of Betar Illit; Yirmiyahu Salem, 48, of Emmanuel; Israel Sternberg, 46, of Emmanuel; David Tzarfati, 38, of Ginot Shomron; Hananya Tzarfati, 32, of Kfar Saba; Ya'akov Tzarfati, 64, of Kfar Saba were killed when three terrorists attacked a No. 189 Dan bus and several passenger cars with a roadside bomb, anti-tank grenades, and light arms fire near the entrance to Emmanuel in Samaria at 18:00 P.M. About 30 others were injured. Both Fatah and Hamas claimed responsibility for the attack.
Haim Chiprot, 52, of Emmanuel, injured in the attack, died of his wounds on March 25, 2002.
Dec 25, 2001 - Sgt. Michael Sitbon, 23, of Beit Shemesh, an IDF reserve soldier, was killed, and four other soldiers were injured, in a shooting attack Tuesday morning near the Jordanian border north of Beit She'an.
Jan 9, 2002 - Maj. Ashraf Hawash, 28, of Beit Zarzir; Sgt.-Maj. Ibrahim Hamadieh, 23, of Rehaniya; Sgt.-Maj. Hana (Eli) Abu-Ghanem, 25, of Haifa; and St.-Sgt. Mofid Sawaid, 25, of Abu Snan, four IDF soldiers of the Bedouin desert patrol unit, were killed and two injured when two armed Palestinian terrorists from the southern Gaza Strip, carrying explosive belts, assault rifles, grenades, and dressed in Palestinian Authority police uniforms, infiltrated into Israel at 04:30 this morning and attacked an IDF post near Kerem Shalom. The terrorists, one a member of the Palestinian Authority's naval force, and the second a Hamas operative, were killed. Hamas claimed responsibility for the attack.
Jan 14, 2002 - Sgt. Elad Abu-Gani, 19, of Tiberias, was killed and an officer sustained gunshot wounds in a terrorist ambush near Kuchin, between Nablus and Tulkarm. Fatah claimed responsibility for the attack.
Jan 15, 2002 - Avraham (Avi) Boaz, 71, of Ma'aleh Adumim, an American citizen, was kidnapped at a PA security checkpoint in Beit Jala. His bullet-riddled body was found in a car in Beit Sahur, in the Bethlehem area. The Fatah's Al-Aksa Brigade claimed responsibility for the murder
http://prague.indymedia.org/front.php3?article_id=3660&group=webcast
http://www.israel-mfa.gov.il/mfa/go.asp?MFAH0ia50
אני בשוק :o
והם טוענים שהאמת שלהם היא ה"אמת"
רק חבל שהם מתעלמים מהעובדות.
אותו מרצה סילף את המציאות על מנת להפיץ את דעותיו הפוליטיות. ולדעתי, אם הוא לא מסוגל לבדוק קודם כל את טענותיו לפני שהוא אומר אותם, הוא לא יכול להיות מרצה באוניברסיטה.
תשלח את זה בתור תגובה לכתבה.
כל אחד אומר משהו אחר... מה שמוכיח שוב שלתשקורת יש חלק פעיל מאוד בכל קרע וסכסוך !
הבעיה היא שאף אחד מהם לא אומר את המציאות
לא מזמן הקשבתי להרצעה מעניינת מאוד מהאוניברסיטה העברית שבה אחד המרצים להסטוריה וארכולוגיה הסביר דבר פשוט מאוד: כל הסטריון שרוצה להתפרסם היום מתחיל לפעול בצורה נהיליסטית אשר שוללת כל טענה מהעבר, והמקום הכי טוב לעשות את זה זה כנגד ההסטוריה היהודית, היות ולהתריס כנגד המדינה היהודית והציונית ולנסות לנתק כל קשר שלה לעם ישראל שהוגלה מכאן - היא דבר פופולארי מאוד בקרב הסטוריונים בינ"ל, ולצערי, גם הסטוריונים יהודים שרוצים "למצא חן" בעיניי אנשי ה"עולם הגדול".
זה אכן נכון, ועצוב.
במאות 17-18 היתה אמרה שהאדם החכם לא לוקח את האמת כמובן מאליו, ומחפש את האמת האמיתית.
הבעיה היא שאותם "אנשי רוח" מודרניים שפשוט לא מספיק חכמים , הולכים אחרי האמרה הזו העיניים עצומות, בלי להבין את משמעותה האמיתית. ומה שקורה הוא פשוט מאוד, הם לא מספיק חכמים בשביל למצוא את האמת, אז הם ממציאים אחת, ועדיף שתסתור את מה שה"אנשים הרגילים" יודעים.
