תאימות של לוחות
יש לי פרוייקט על UNO ואני רוצה להעביר אותו לnano הזה
http://cdn.hobbyking.com/hobbyking/store/catalog/25086.jpg
תהיה בעיה עם הקוד?
/** Clapper project
* Author: Manoj Kunthu
* Update: 2/2/13
* Method Prototypes
void initialize();
void runDetector();
boolean clapDetected();
int detectClaps(int numClaps);
void indicateClaps();
void readMic();
void printStats();
* Variable Declarations
int TOTAL_CLAPS_TO_DETECT = 2; //The number of claps detected before output is toggled
int offset = 80; // The point above average that the clap is detected
int CLAP_TIME=4000; // The time allowed between each clap
int sensorValue = 0; //the value read through mic
int toggleOutput = -1;
int SIZE = 3;
int buffer[3];
int loopIteration = 0;
int average = 0;
int total = 0;
//BOARD INPUT MIC
const int inPin0 = A0;
//BOARD OUTPUT SIGNALS
const int clapLed1 = 12, clapLed2 = 11, out = 10, readyPin = 13;
//CLAP STATE CONSTANTS
const int FINAL_DETECTED = 0, LOST_CONTINUITY = 1, CLAP_NOT_DETECTED = 2;
void setup() {
Serial.begin(9600);
//direct representation of the light bulb that toggles on/off
pinMode(out, OUTPUT);
//once initialize() runs the ready pin turns on
pinMode(readyPin, OUTPUT);
//respective clap LEDs, more can be added
pinMode(clapLed1, OUTPUT);
pinMode(clapLed2, OUTPUT);
void loop() {
initialize();
runDetector();
* Purpose: Prepares the buffer to recognize ambient noise levels in room.
void initialize()
loopIteration = 0;
total = 0;
average =0;
digitalWrite(clapLed1, LOW);
digitalWrite(clapLed2, LOW);
digitalWrite(out, LOW);
for(int i = 0; i < SIZE; i++)
readMic();
buffer[i] = sensorValue;
total = total + sensorValue;
average = (total/(i+1));
Serial.print("INIT - AVE: ");
Serial.print(average);
Serial.print(" Total: ");
Serial.print(total);
Serial.print(" Sensor: ");
Serial.print(sensorValue);
Serial.print(" Change: ");
Serial.println(sensorValue-average);
delay(50);
digitalWrite(readyPin, HIGH);
* Purpose: Runs the detector algorithm. Developers can change the number of claps by adjusting TOTAL_CLAPS_TO_DETECT variable up at the top.
void runDetector()
while(true)
int clapState = detectClaps(TOTAL_CLAPS_TO_DETECT);
if(clapState == FINAL_DETECTED || clapState == LOST_CONTINUITY)
Serial.println("--done--");
indicateClap(0);//turn off any clap indicating lights
* Purpose: Detects the number of claps specified. This method is recursive
int clapNum = numClaps;
//Base Case - if clapNum is 0, then all claps have been accounted.
if(clapNum == 0)
//the output can now be toggled.
toggleOutput *= -1;
indicateClap(clapNum);
Serial.println("----- Clap Limit Reached - Output Toggled -----");
return FINAL_DETECTED;
//Read from mic and update ambient noise levels.
readMic();
total = (total - buffer[loopIteration]) + sensorValue;
average = (total/SIZE);
buffer[loopIteration] = sensorValue;
loopIteration = (loopIteration+1)%SIZE;
if(clapDetected())
Serial.print("detectClaps - Claps:");
Serial.println(TOTAL_CLAPS_TO_DETECT + 1 - numClaps);
printStats();
delay(100);
for(int i = 0; i < CLAP_TIME; i++)
int clapState = detectClaps(clapNum - 1);
return clapState;
return LOST_CONTINUITY;
return CLAP_NOT_DETECTED;
* Purpose: Turns the LED on appropriately to signal a clap detection.
void indicateClap(int clapNum)
if(clapNum == 0)
if(toggleOutput == 1)
digitalWrite(out, HIGH);
else
else if(clapNum == 1)
digitalWrite(clapLed1, HIGH);
else if(clapNum == 2)
digitalWrite(clapLed2, HIGH);
delay(110);
* Purpose: Prints basic statistics data for more info with sensor readouts and data points.
void printStats()
Serial.print("--- AVE: ");
//Serial.print(" iterNum: ");
//Serial.print(loopIteration);
Serial.println(sensorValue-average); //This is what I used to determine the 'offset' value
* Purpose: A clap is detected when the sensor value is greater than the average plus
* an offset. The offset might need to be fine tuned for different sound sensors.
return sensorValue > average + offset;
* Purpose: Reads mic input and stores it in a global variable.
void readMic()
sensorValue = analogRead(inPin0);
לא אמורה להיות שום בעיה, במקרה הכי גרוע תצטרך לשנות את מספר הפין שמדליק את הלד או מספר הפין שאליו מחובר המיקרופון.
