BSOD מייאש.. חייב למצוא פתרון
שלום
כבר כמעט חודשיים יש לי קריסות במחשב סתם ככה גם אם אני לא נוגע בו.. לפעמים רואים את הBSOD ולפעמים סתם רואים מסך שחור
פתחתי את הקובץ dmp האחרון אבל אני לא ממש מבין מה הסיבה שם
כתוב שם גם VISTA_DRIVER_FAULT וגם memory_corruption
ומז"א השורה "Some register values may be zeroed or incorrect" ?
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*c:\symbols*[url]http://msdl.microsoft.com/download/symbols[/url]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`02e0e000 PsLoadedModuleList = 0xfffff800`0304be50
Debug session time: Thu May 6 15:16:14.995 2010 (UTC + 3:00)
System Uptime: 0 days 0:41:19.042
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffdf018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {2a80041d0268, 2, 0, fffff80002f0e095}
Probably caused by : memory_corruption ( nt!MiGetTopLevelPfn+65 )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00002a80041d0268, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002f0e095, address which referenced memory
Debugging Details:
READ_ADDRESS: 00002a80041d0268
CURRENT_IRQL: 2
FAULTING_IP:
fffff800`02f0e095 4c8b4928 mov r9,qword ptr [rcx+28h]
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffff880073414e0 -- (.trap 0xfffff880073414e0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000001000015f00c rbx=0000000000000000 rcx=00002a80041d0240
rdx=fffffff5557bc079 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002f0e095 rsp=fffff88007341678 rbp=0000000000000005
r8=fffffe00073416b0 r9=000001000015f00c r10=fffff88007341728
r11=0000000000000001 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
nt!MiGetTopLevelPfn+0x65:
fffff800`02f0e095 4c8b4928 mov r9,qword ptr [rcx+28h] ds:0100:0268=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002e7db69 to fffff80002e7e600
STACK_TEXT:
fffff880`07341398 fffff800`02e7db69 : 00000000`0000000a 00002a80`041d0268 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`073413a0 fffff800`02e7c7e0 : 00000000`00000000 000fffff`ffffffff 00000000`42506650 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`073414e0 fffff800`02f0e095 : fffff800`02f30f12 00000100`0015f00c fffffa80`0563a798 00000000`000018c0 : nt!KiPageFault+0x260
fffff880`07341678 fffff800`02f30f12 : 00000100`0015f00c fffffa80`0563a798 00000000`000018c0 fffff800`031461af : nt!MiGetTopLevelPfn+0x65
fffff880`07341680 fffff800`02f3170b : 00000000`00000000 00000000`00000004 fffffa80`0563a798 fffffa80`05639000 : nt!MiIdentifyPfn+0x722
fffff880`07341720 fffff800`03290c55 : fffffa80`05639000 fffff880`07341ca0 fffff880`073417f8 00000000`00000000 : nt!MmQueryPfnList+0xbb
fffff880`07341760 fffff800`031d5f18 : 00000000`00000006 00000000`00000000 fffffa80`05639000 fffff800`02e0e001 : nt!PfpPfnPrioRequest+0x115
fffff880`073417b0 fffff800`0317cfb3 : 00000000`00000000 fffff800`02e0e000 fffffa80`00000001 fffff880`100c3c01 : nt! ?? ::NNGAKEGL::`string'+0x4759d
fffff880`07341840 fffff800`0317e149 : 00000000`01b2bce8 fffff880`07341ca0 00000000`01b2bd40 fffff800`02e7d6d8 : nt!ExpQuerySystemInformation+0x11c2
fffff880`07341be0 fffff800`02e7d853 : 00000000`0321aed8 fffff880`07341ca0 00000000`03239490 00000000`033f74e0 : nt!NtQuerySystemInformation+0x4d
fffff880`07341c20 00000000`76d7021a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`01b2bc18 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76d7021a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiGetTopLevelPfn+65
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4b88cfeb
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiGetTopLevelPfn+65
1: kd> .trap 0xfffff880073414e0
מישהו יכול לעזור לי בלהבין את הבעיה?
למה לפתוח דיון כפול?
קיבלת אזהרה על דאבל פוסטינג.
מדובר באזהרה הראשונה שלך כאשר בשלישית תורחק/תושתק מהפורום.
הדיון ננעל.
