2007WFP, לא מה שאנחנו חושבים?
שלום לכולם,
כמו רוב האנשים כאן גם אני קראתי את הביקורות על הדגם המוצלח של DELL והתלהבתי.
עד שנתקלתי בקטע הבא:
Several manufacturers, including Dell and Samsung, have played the panel "bait and switch" game thinking no one would notice. A controversial practice called a "panel lottery" by others, they will originally release a good panel (for reviewers) and switch to an inferior one later on (probably to make some more money). Dell first put an S-IPS in their 2007WFP and later switched to an S-PVA, whose performance was deemed very low compared to the S-IPS. Samsung originally was making "S" (Samsung) TN panels for their 226BW, until they outsourced their production to AU Optronics ("A"), CMO ("C"), and CPT ("P"). The A, C, and P panels performed poorly at the default color settings. All of their colors were equal after calibration, although the C panel had more issues with response time. Since many folks don't own a colorimeter, they will end up with a panel that can't display colors with the same fidelity as the original "S" panel. Later, both Dell and Samsung began hiding the panel information from the service menu and the back panel.
In an interview, Samsung stated that after April 1st they would release only "S" panels (in France). Three Frenchmen discovered 2 A panels and 1 C panel with their 226BWs manufactured after April 1.
Dell and Samsung claim that they did this because of stock problems. Well, if they didn't have enough stock why did they continue selling it under the same model name? It obviously makes it frustrating for users who try to pick the right panel. It doesn't help that the "alternate panel" often falls way behind the original.
HP also has switched to AMVA in its HP LP2065 model in some cases, but at least they registered the change with the FCC in publicly available format unlike Dell/Samsung who really kept it under the covers. HP did keep a label on their box also indicating the panel.
The main purpose of this section was to raise awareness of this problem, and hopefully send a message to the vendors involved that the panel-switching needs to stop.
Update (07/14/2007): It seems as though HP has switched to all AMVA panels for the LP2065. For this reason, it has been removed from the recommendations
ללינק: http://forums.anandtech.com/messageview.aspx?catid=31&threadid=2049206
בקיצור נמרץ מסתבר ש DELL שלחה ל Reviews את הדגם עם הפאנל S-IPS שקיבל כמובן ביקורות נלהבות ולמשתמשים יצרה דגם עם הפאנל הנחות יותר S-PVA
כמו כן, נכנסתי לאתר של DELL ולא כתוב בספציפיקציות את סוג הפאנל, (למה לא?!)
אשמח אם מישהו יוכל להזים את החששות שלי...
למסך 2007wfp/fp ישנן 2 פאנלים: S-IPS,S-PVA.
עד עכשיו לא שמעתי שמישהו בארץ קנה את הדל עם הפאנל S-PVA.
בכל זאת כדי להיות בטוח תדרוש בקנייה שלך מהחנות שהמסך יהיה בעל פאנל S-IPS (כיום יש חנויות שאפילו מתחייבות לכך כמו פנדה).
ולאחר מכן כמובן תוכל לבדוק אם באמת הוא בעל פאנל S-IPS או פאנל S-PVA.
1. בארץ נמצא העיקר הפנל S-IPS למרות שמספר אנשים קיבלו את הS-PVA
2. כאחד שראה את שני הפנלים ההבדל הוא לא כזה גדול גם עם פנל S-PVA המסך עדיין הכי טוב בתקציבו.
3. יש חנויות שמתחייבות לסוג הפנל.
אז אפשר להירגע :)
איך בכל זאת אני בודק אם הפאנל שקיבלתי הוא מה שאני חושב שהוא?
ובלי קשר... האם Revision 5 יכול להיות פחות טוב מ revision 4? יש עליו ביקורות כבר?
borsood,
אתה יכול להגיד איזה חנויות נותנות התחייבות לסוג הפאנל?
1. חיפוש בפורום
2. אני לא חושב שזה מותר לפי חוקי הפורום
3. תשאל את החנות שבה אתה מתכוון לקנות
