בעיה מוזרה בC++
אני עשיתי חלון בC++ אבל משום מה הפעילות של החלון לא נגמר אחרי סוף התכנית אני ב Task Manager
ב Processes שהתוכניתרצה איך לתקן את זה?
#include <windows.h>
#include <d3d9.h>
#include <d3dx9.h>
//globals
LPDIRECT3DDEVICE9 p_Device;
bool AppRunning = true;
//end globals
//functions
HWND NewWindow(LPCTSTR str_Title,int int_XPos, int int_YPos, int int_Width, int int_Height,HINSTANCE h);
LRESULT CALLBACK OurWindowProcedure(HWND han_Wind,UINT uint_Message,WPARAM parameter1,LPARAM parameter2);
LPDIRECT3DDEVICE9 InitDevice(HWND wnd);
void DrawScene();
//end Functions
int WINAPI WinMain(HINSTANCE hInstance,HINSTANCE hPreviousInstance,LPSTR lpcmdline,int nCmdShow)
MSG msg;
HWND wnd = NewWindow("stamchalon",100,100,500,500,hInstance);
ShowWindow(wnd,SW_SHOW);
UpdateWindow(wnd);
p_Device = InitDevice(wnd);
while(AppRunning)
if(PeekMessage(&msg,NULL,0,0,PM_REMOVE))
if(msg.message == WM_QUIT)
break;
TranslateMessage(&msg);
DispatchMessage(&msg);
else{
DrawScene();
p_Device->Release();
DestroyWindow(wnd);
return 0;
WNDCLASSEX wnd_Structure;
wnd_Structure.cbSize = sizeof(WNDCLASSEX);
wnd_Structure.style = CS_HREDRAW | CS_VREDRAW | CS_OWNDC;
wnd_Structure.lpfnWndProc = OurWindowProcedure;
wnd_Structure.cbClsExtra = 0;
wnd_Structure.cbWndExtra = 0;
wnd_Structure.hInstance = h;
wnd_Structure.hIcon = NULL;
wnd_Structure.hCursor = NULL;
wnd_Structure.hbrBackground = GetSysColorBrush(COLOR_BTNFACE);
wnd_Structure.lpszMenuName = NULL;
wnd_Structure.lpszClassName = "DragonFighters";
wnd_Structure.hIconSm = LoadIcon(NULL,IDI_APPLICATION);
RegisterClassEx(&wnd_Structure);
return CreateWindow(str_Title,str_Title,WS_OVERLAPPEDWINDOW,CW_USEDEFAULT,CW_USEDEFAULT,500,500,0,0,h,0);
switch(uint_Message)
case WM_DESTROY:
PostQuitMessage(0);
return 0;
case WM_PAINT:
ValidateRect(han_Wind,0);
return 0;
break;
return DefWindowProc(han_Wind,uint_Message,parameter1,parameter2);
LPDIRECT3D9 p_dx_Object = Direct3DCreate9(D3D_SDK_VERSION);
if(p_dx_Object == NULL)
MessageBoxA(wnd,"DirectX is not installed","Error",MB_OK);
AppRunning = false;
D3DPRESENT_PARAMETERS dx_PresParams;
ZeroMemory( &dx_PresParams, sizeof(dx_PresParams) );
dx_PresParams.Windowed = TRUE;
dx_PresParams.SwapEffect = D3DSWAPEFFECT_DISCARD;
dx_PresParams.BackBufferFormat = D3DFMT_UNKNOWN;
LPDIRECT3DDEVICE9 p_dx_Device;
p_dx_Object->CreateDevice(D3DADAPTER_DEFAULT, D3DDEVTYPE_HAL, wnd, D3DCREATE_HARDWARE_VERTEXPROCESSING, &dx_PresParams, &p_dx_Device);
if (FAILED(p_dx_Object->CreateDevice(D3DADAPTER_DEFAULT, D3DDEVTYPE_HAL, wnd, D3DCREATE_HARDWARE_VERTEXPROCESSING, &dx_PresParams, &p_dx_Device)))
if (FAILED(p_dx_Object->CreateDevice(D3DADAPTER_DEFAULT, D3DDEVTYPE_REF, wnd, D3DCREATE_SOFTWARE_VERTEXPROCESSING, &dx_PresParams, &p_dx_Device)))
MessageBox(wnd,"Failed to create even the reference device!","Error",MB_OK);
return p_dx_Device;
void DrawScene()
p_Device->Clear(0,NULL,D3DCLEAR_TARGET,D3DCOLOR_XRGB(0,0,0),1.0f,0);
p_Device->BeginScene();
//here we draw our scene
p_Device->EndScene();
p_Device->Present(NULL,NULL,NULL,NULL);
למה פשוט לא לעבור ל XNA או managed directx..
בכל מקרה, נראה לי שהבעיה אולי קשורה לזה שאתה בודק אם יש WM_QUIT שזה קורה כששולחים למשל PostQuitMessage שאתה קורא לו ב WM_DESTROY שהוא קורה כששולחים DestroyWindow אבל את זה אתה עושה אחרי ה WM_QUIT.
איך אתה יוצא מהתוכנה ? ע"י לחיצה על כפתור ה X בחלון ?
כן בלחיצה על כפתור ה X בחלון
נסה להוריד את הבדיקה של WM_QUIT בלולאה הראשית. בפונקציית טיפול ההודעות, תוסיף טיפול ב WM_CLOSE שם תעשה את ה Release ו DestroyWindow (במקום איפה שהם עכשיו). וב WM_DESTROY תעשה PostQuitMessage(0);
אני לא מבין אנשים שכותבים עוד UI ב- C++
מה רע ב C++ ? יש את MFC ו WTL שדי מקלים על הנושא...
האמת מעניין באמת לכמה אנשים במחשב (בלי כרטיס מסך של ATI) מותקן ה .NET framework על המחשב.
אפשר ב- .net 2 לפתח UI עשיר , מודרני וידידותי מאוד למשתמש בכמעט אפס שורות קוד
וכך זה מותיר לך זמן כמפתח לעסוק בנושאים יותר מתקדמים
אין שום סיבה שכמתכנת אני אכתוב למשל קוד שאם אני מגדיל חלון אז יתר הרכיבים בתוך החלון גדלים ו\או נצמדים לשוליים בהתאמה לגודל החלון
לעשות משימה כזו ב- C++ יכול לקחת מאות שורות קוד, ב- .net אין צורך לדאוג לזה בכלל
צריך לדעת לבחור נכון את שפת התכנות לכל מטרה, הדבר אחרון שהיתי עושה עם C++ זה UI
כל אחד ומה שהוא רגיל אליו :)
ד"א מה שהוא עושה פה זה לא UI, הוא לומד מ tutorial ל directx רגיל, אומנם יש גם managed DX אבל פה הוא לא בונה ממשק..
יש גם ספריות שעוזרות לבנות ממשק שמאפשר דברים כאלו גם ב MFC, ועדיין מרבית התוכנות בעולם לא כתובות ב .NET (גם כאלו שיוצאות היום).
לא עבד
תראה את הקוד החדש.
הנה
אבל אם אני דיבוג ואז רליס אז התוכנית נגמרת ולהפך
#include "resource.h"
#include <d3d9.h>
#include <d3dx9.h>
#include "Terrain.h"
#define Radians (D3DX_PI/180)
#define Degrees (180/D3DX_PI)
#define ToRadians(n) n * Radians
#define ToDegrees(n) n * Degrees
//globals
HWND wnd;
D3DXMATRIXA16 m_world;
D3DXMATRIXA16 m_view;
D3DXMATRIXA16 m_projection;
LPDIRECT3DTEXTURE9 texture=NULL;
Terrain *te;
float angle = 0;
struct CUSTOMVERTEX
float x,y,z;
float u,v;
#define CVFVF D3DFVF_XYZ | D3DFVF_TEX1
//end globals
//functions
LRESULT CALLBACK WindowProcedure(HWND han_Wind,UINT uint_Message,WPARAM parameter1,LPARAM parameter2);
void SetUpVertices(HWND wnd);
void SetUpCamera();
void DrawScene();
//end Functions
MSG msg;
wnd = NewWindow("DragonFighters",100,100,700,700,hInstance);
UpdateWindow(wnd);
SetUpCamera();
te = new Terrain(wnd,p_Device);
te->LoadHugeTerrain("test.raw");
p_Device->SetRenderState(D3DRS_LIGHTING,false);
if(D3DXCreateTextureFromFile(p_Device, "C://test.dds",&texture)!=D3D_OK)
MessageBox(wnd,"Cannot load texture","Error",MB_OK);
PostQuitMessage(0);
while(AppRunning)
//if(msg.message == WM_QUIT)
// break;
else{
DrawScene();
delete te;
PostQuitMessage(0);
DestroyWindow(wnd);
return 0;
wnd_Structure.lpfnWndProc = WindowProcedure;
wnd_Structure.hIcon = LoadIcon(h,MAKEINTRESOURCE(IDI_DRAGONFIGHTERSICON));
wnd_Structure.hIconSm = LoadIcon(h,MAKEINTRESOURCE(IDI_DRAGONFIGHTERSICON));
return CreateWindow(str_Title,str_Title,WS_OVERLAPPEDWINDOW,CW_USEDEFAULT,CW_USEDEFAULT,int_Width,int_Height,0,0,h,0);
case WM_DESTROY:
PostQuitMessage(0);
return 0;
case WM_CLOSE:
if(texture!=NULL)
texture->Release();
case WM_PAINT:
return 0;
break;
AppRunning = false;
return p_dx_Device;
void SetUpCamera()
D3DXVECTOR3 pos(0,0,15.0f);
D3DXVECTOR3 target(0,0,0);
D3DXVECTOR3 up(0,1,0);
D3DXMatrixLookAtLH(&m_view,&pos,&target,&up);
p_Device->SetTransform(D3DTS_VIEW,&m_view);
RECT rect;
GetWindowRect(wnd,&rect);
D3DXMatrixPerspectiveFovLH(&m_projection,D3DX_PI/4,(rect.right-rect.left)/(rect.bottom-rect.top),1,50);
p_Device->SetTransform(D3DTS_PROJECTION,&m_projection);
void DrawScene()
p_Device->Clear(0,NULL,D3DCLEAR_TARGET,D3DCOLOR_XRGB(72,61,139),1.0f,0);
p_Device->SetRenderState(D3DRS_CULLMODE,D3DCULL_NONE);
//D3DXMATRIXA16 rotation;
//D3DXMatrixRotationYawPitchRoll(&rotation,angle,angle/2,angle/3);
//D3DXMATRIXA16 transaltion;
//D3DXMatrixTranslation(&transaltion,-5,-5,-5);
//D3DXMatrixMultiply(&m_world,&transaltion,&rotation);
//p_Device->SetTransform(D3DTS_WORLD,&m_world);
//p_Device->SetTexture(0,texture);
// p_Device->SetStreamSource(0, p_buffer, 0, sizeof(CUSTOMVERTEX));
// p_Device->SetFVF(CVFVF);
// p_Device->DrawPrimitive(D3DPT_TRIANGLESTRIP, 0, 4);
te->Render();
angle+=ToRadians(2);
אין לי את ה DX SDK מותקן, אבל נסה:
#include <d3d9.h>
#include <d3dx9.h>
//globals
HWND wnd;
Terrain *te;
float angle = 0;
struct CUSTOMVERTEX
float x,y,z;
float u,v;
//end globals
//functions
void SetUpCamera();
void DrawScene();
//end Functions
MSG msg;
UpdateWindow(wnd);
SetUpCamera();
PostQuitMessage(0);
while(AppRunning)
} else {
DrawScene();
delete te;
return 0;
case WM_DESTROY:
PostQuitMessage(0);
AppRunning = false;
return 0;
case WM_CLOSE:
if(texture!=NULL)
texture->Release();
DestroyWindow(han_wind);
break;
case WM_PAINT:
return 0;
break;
AppRunning = false;
return p_dx_Device;
void SetUpCamera()
RECT rect;
void DrawScene()
te->Render();
לא עובד
