פורסם 2007 באפריל 819 שנים http://support.microsoft.com/?kbid=925902זה ההודעה שלך באדום לא..?Known issuesloadTOCNode(2, 'summary');After you install this security update on a Windows XP Service Pack 2 (SP2)-based computer, Realtek HD Audio Control Panel (Rthdcpl.exe) may not start. Additionally, you receive an error message that is similar to the following: Rthdcpl.exe - Illegal System DLL RelocationThe system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: 935448 (http://support.microsoft.com/kb/935448/) The Realtek HD Audio Control Panel may not start, and you receive an error message when you start the computer: "Illegal System DLL Relocationפיתרון כאן:http://support.microsoft.com/kb/935448/תחת RESOLUTIONקצת גוגל..שבוע טוב!בראל.
