יש לי רק 60 FPS ב-DOOM 3 ..
תגיד, כשאני מבטל את הV SYNC בדרייברים...
בכל המשחקים אני אמור לקבל לפחות 100FPS או לפחות FPS ללא מגבלה של 60 ?
זה לא קשור, זה יותר קשור למנוע של המשחק וכמובן לחומרה שלך
תיראה מה קראתי פה..
Vertical Sync: Vertical Synchronization (also called Vertical Sync, or simply VSync) is the synchronization of your graphics card and monitor's abilities to redraw the screen a number of times each second (measured in FPS or Hz). If VSync is disabled (set to No), you may see some image "tearing" as your monitor and graphics card go slightly out of synchronization when the refresh rate exceeds the monitor's abilities, however your FPS can now exceed your monitor's refresh rate. There is something important to understand when talking about VSync and Doom 3 though - the Doom 3 engine is specifically capped at 60FPS, so normally you cannot exceed this framerate regardless of your VSync setting (you can exceed it by using the com_fixedtic -1 command - see Advanced Tweaking section). You can still have a refresh rate higher than 60Hz, it's just that your monitor will simply show some frames more than once. It is always recommended that you have as high a refresh rate as possible to ease eyestrain (See Advanced Tweaking section). Whether VSync should be on or off in Doom 3 is not set in stone - it differs by system. Some people have reported to me that they get better, and more importantly smoother framerates with VSync enabled (Set to Yes). Others show through their Timedemo results (See Neat Stuff & Conclusion section below) that having VSync off improves their average FPS. You will need to experiment, but to begin with I recommend firstly checking your graphics card control panel to ensure that the Vertical Sync option there is set to 'Application Preference', and then in Doom 3 set VSync Off. If you are happy with it, keep it off, however if you find the image "tearing" too annoying, or want smoother FPS, then set VSync back to On. Also run a Timedemo with VSync on and off and see what your particular results show.
אני מבין שאת השורה הזאת פיספסת:
שורה אחת מתחת למה שסימנת ;)
העתקתי את זה וזה לא נתן לי משהו..
רושם שאין פקודה כזאת..
אולי צריך לעשות משהו עם ה-VSYNC ?
ורשום שם שלבעלי כרטיס מסך עם 256 זיכרון הפילטרים פועלים אוטמטית על 8* ..
אצלי זה כלום..
לא קראתי את ה Advanced Tweaking section שהם מדברים עליו אבל ההגיון אומר שהפקודה היא
com_fixedtic -1
