need help to change for heb
hello:D
i install winx64 and i have a prob i cant write in hebrew and i see all the hebrew from left to right
if someone can help me plz
10q
Under: Regional and Language Options, make sure that your location is set to Israel, on the next tab (Languages) make sure that the first box is checked, and on the Advanced tab, make sure Hebrew is selected and check all the boxes that have Hebrew in them
ok i check again ....but where i can do something with hebrew lan` i mark
so the problem stay
if i update my font list its help me?
anyway if some1 know way to fix it up HELP ME :D
some one:|
