Command And Conquer 3 Announced!
Ladies and Gentlemen, the new C&C cat is out of the bag...
You have this from me: this is not a joke, this is not a hoax. The cover story of the June issue of PC Gamer is, in fact, a preview of the next Command & Conquer game, simply titled C&C 3.
I expect we will be hearing more from EA on this matter shortly in the form of a press release type thing.
Let me repeat for those of you who skimmed the news instead of reading:
C&C 3 HAS BEEN ANNOUNCED
This is not a drill. Pick up the June copy of "PC Gamer" for a preview.
  • תגובות 76
  • צפיות 8k
מגניב!!!
אפשר לדעת מאיפה הציטוט?
לא משנה, מצאתי.
According to the PC Gamer article the story behind the new C&C game revolves around the world been thrown into chaos due to the spread of Tiberium. As a result 20% of the Earth's surface has become Tiberium-infested and is now inhospitable (these areas are Red Zones). Tiberium hasn't fully taken hold of 50% of the Earth (these areas are Yellow Zones) and the rest of the Earth is more or less safe (these areas are called Blue/Green zones) this area is also where the GDI is headquartered. The GDI is trying to prevent the spread of Tiberium and convert the Yellow Zones to Blue Zones. The only other information the article give us it that the game will use the SAGE engine (from C&C Generals) but it will be heavily modified. It also says Kane will be returning and Live-action scenes will be making a comeback to the C&Cverse .
http://darkzero.co.uk/news.php?newsid=9354
C&C 3 Announced!
No joke. Pick up a June 2006 issue of PC Gamer to read all about the next RTS game in the Command & Conquer series, simply titled "C&C3".
http://planetcnc.gamespy.com/
אני שמח, אבל בטוח שEA ידפקו את המשחק. :'(
אחרי מה שEA עשו לזכיון של הסנדק ואחרי 1000000000000 מישחקים לא מקורים וממוחזרים
של EA
אני לא מצפה למישחק הזה
אני אולי אוהב את סידרת Command And Conquer
ביגלל הפשטות שלה אבל בידי EA בטח יצא מישחק משעמם שיחזור על עצמו תוך שעה אחת
יהיה באמת חבל אם החלק השלישי לא יהיה כייפי כמו הקודמים, אינ מקווה שם רק יוסיפו/ישנו את הטנקים/חיילים ישפרו קצת את הגרפיקה (לא הרבה-שאני אוכל לשחק גם) ושכל השאר ישאר זהה ל RR2
יש לי רק דבר אחד להגיד:
H O L Y M O T H E R O F G O D ! ! !
לפני 10 שנים כאשר יצא המשחק הראשון של RED ALERT הוא הפך למשחק האהוב עליי בכל הזמנים. גם במקביל הC&C הראשון היה מטורף (לזמנו).
אז הייתי בן 11. כיום אני בן 21 עוד 3 חודשים משתחרר מהצבא, וזה עדיין מעביר בי את אותם רגשות דה ז'ה וו יפים ומתוקים מהעבר.
אז מה היה לנו בזמן האחרון מהסדרה הזאת?
הוציאו את חבילת C&C DECADES שאיחדה בחבילה אחת את כל המשחקים בסדרה:
ואחרי הנשקים האחרונים שהוצגו בGENERALS ZERO HOUR אני ממש מצפה לחידושים במשחק החדש. מה אפשר כבר להמציא מעבר לזה:
http://www.cncsaga.com/index.php?web=1;26;2;0;71
פצצה לגבה האמצעית, שיחקתי עוד מהמשחק הראשון, והשיא שהיה generals, נקווה ש3 יהיה טוב.
המשחק ה3 נראה יותר כמו המשך של סדרת המשחקים Tibirien SUN
Tiberian Sun היא חלק מ- Command And Conquer
של EA
ובכל זאת תשחק במשחק כמו גדול.
אגב,
הייתי משתמש במילה REVEALED במקום ANNOUNCED...
אגב,
אני מחקתי את הסנדק תוך 5 דקות ואין סיבה שזה לא יקרה במידה והמישחק הזה גם יסריח
יה!
אהבתי את הסדרה!
יש בנתיים תאריכים?
אלוואי שיצא מזה משהו טוב שלפחות ימשיכו את הסדרה כראוי ולא לכישלון.
דבר שני: אני מקווה שעדיין נשאר להם מפתחים מוובסוט כדי שיוכלו לעזור בתכנון המשחק
להההההההההה באמת?? ::)
:lol:
אם כבר: ווסטווד . . . WESTWOOD R.I.P
הסנדק בתכלס היה אכזבה. השגתי אותו ומחקתי אחרי חצי שעה של שיטוטים, בדיקת תנועות ויכולות וגרפיקה. רק הגרפיקה נראית איכשהו בסדר. הבעייה היא שהשליטה מאעפנה לחלוטין, והמכות זה כבר בכלל טראומה שקיבלתי. היו צריכים לתת לROCKSTAR, המפתחים של GTA לפתח את המשחק הזה. הם היו עושים משהו שהוא שילוב בין גניבת הרכבים ,המשימות,והתנועות החלקות של GTA לבין הסרט המקורי.
בכל מקרה, למי שמתבלבל וכבר לא זוכר מי היו VNOD ו GDI:
הGDI היו הטובים והNOD היו הרעים במשחק המקורי מ1995.
הוא נקרא COMMAND AND CONQUER המקורי. אחריו הגיע TIBERIAN SUN שנקרא בסלנג: C&C2 ( אחריו הופיע RENEGADE) ששוחק בתוך אותו עולם.
RED ALERT הופיע ב1996. אחריו הופיע RED ALERT 2 שהיה משחק מאעפן עם גרפיקה מבזה.ומאז כולם מחכים לRA3. והייתה פעם הכרזה שהC&C הבא יהיה בתוך העולם של RA2 . . . וזה התבדה כנראה, או לחילופין - הם עובדים בחשאי על RED ALERT 3 . . . :jump:
זה ממרץ 2005:
http://gamer.co.il/gamer2/php/doc.php?id=41764
ועכשיו לכמה דברים מסתוריים:
התמונה הזאת מציגה את נשק קרן הלייזר ION CANNON שהופיע בZERO HOUR . . .
הבעיה היא שגם זאת תיאורטית מראה משהו שאמור היה להופיע . . . החיילים שבינינו יודעים שאמור זה "שם של דג",וגם אותו אוכלים, אבל עדיין תראו:
ותמונה מתוך סרטון שמישהו מצא:
זה מתיישבי עם תמונה מסתורית שמסתובבת ברשת ומראה את המשחק עצמו(תראו את הקרן הכחולה שהתמונה עם המסך היא מין המשך של התמונה עם הטנק! אבל זה רק אבחון שלי אישי):
באדיבות פורום C&C בגיימר:
"טוב בקשר לתמונה הישנה.. דלפי[היה מנהל הקהילה של ווסטווד..] אמר שאין קשר בין התמונה הישנה שנחשפה לCNC3 ולמה שעכשיו..
[אני עכשיו קורא את התגובות בPCNC] הינה :
Those images were very real taken from the Westwood Studios version of C&C III back in 2002 and 2003. I am 100% positive the game looks nothing like those images you have posted.
Delphi
Game Designer
Petroglyph
והכתב של PCNC אמר:
Knowledge I was entrusted with but feel it is safe to reveal at this time:
C&C 3 will be:
- Tiberium universe (or, at least, some other dark alt-universe [i haven't read the PC Gamer article yet])
- "Serious" atmosphere (i.e., not like RA2)
These two points are almost certainly addressed in the PC Gamer preview.
Obviously, there is liable to be an EA C&C3 floor presence at E3"
OMG! גילו למנהלי האתרים הגדולים של CNC כבר לפני חודשיים על זה!! עכשיו שזה בחוץ הם חושפים קצת מידע, הם ידעו שהפוסטרים שבאים עם העשור הראשון הם הקונספטים למשחק החדש!(את זה אמר C&CKing מהאתר cncnz.com) וקודם כבר כתבתי את מה שחשף הכתב שלPCNC..
.. עכשיו צריך לחכות ש Lion מcncden יעדכן ויחשוף את המידע שהיה אצלו :) וכמובן להודעה הרשמית מEA..למרות שעצם העבודה שזה בגיליון..זה כבר אומר שיש אישור והכרזה רישמית..רק צריך לחכות להכרזה הנפרדת באתר של EA
עריכה : יהיו סרטים!!!(אם הבנתי נכון) וקיין חוזר!!!!!! אבל לא כתוב מי ישחק אותו!!!!! ו-
The game will use the SAGE engine אבל ישופץ כמו בBFME2
